Thread started 27 Jun 2014 (Friday) 11:39
5diii - slower SD card that maxes its throughput
a_dee
Jun 27, 2014 11:39 |  #1
Hi gang,
I wasn't able to find this information out, but what's the slowest SD card (hence cheapest) that you can buy which still maxes out the camera's 133x SD interface? Obviously buying anything fast would be wasted and money better spent on the CF.
More so looking at cards available from the Lexar and Sandisk line. So far I think Ultra doesn't reach 133x write and then the next step up is Extreme which jumps up to 45/80 mb/s, but what about Platinum II 200x?
Thanks!
6D . SL1
EF-S 24mm f/2.8 . 40mm f/2.8 . 85mm f/1.8 . 70-200mm f/4L IS
Speedlite 430EX . Kenko 1.4x Pro 300DG . Kenko Extension Tube Set
Gone for Now: 5D3 . Rokinon 14mm f/2.8 . 20mm f/2.8 . 35mm f/1.4L
John ­ from ­ PA
Joined May 2003
Jun 27, 2014 11:53 |  #2
Analysis paralysis...
Lay
Joined Oct 2013
Jun 27, 2014 12:02 |  #3
http://robgalbraith.co​m/index-2.html (external link)
Select "CF/SD/XQD" and then choose the 5D III
a_dee
Jun 27, 2014 12:04 |  #4
Yah, I saw that, but it didn't have cards like the Platinum II 200x unfortunately.
Lay wrote in post #16997814 (external link)
6D . SL1
Lay
Joined Oct 2013
Jun 27, 2014 12:37 |  #5
http://www.lexar.com …-ii-sdhc-sdxc-uhs-i-cards (external link)
The write speed should be at least 20MB/s (the limit).
Those Lexar cards 16GB and higher capacity are (up to 30MB/s read, 22MB/s write)
I have SanDisk Extreme SDHC 30MB/s that should be (up to 30MB/s read/write)
827 views & 0 likes for this thread, 3 members have posted to it.
1296 guests, 121 members online
