Thread started 01 Jul 2014 (Tuesday) 22:13
Put behind the eight-ball
AlFooteIII
Joined Jul 2013
Jul 01, 2014 22:13 |  #1
OK, this is one of those lovely posts of someone who got in a situation they should know better, yet here they are. Any helpful suggestions are thankfully welcome.
I got roped into shooting a bunch of corporate portraits. The Powers That Be ordered a basic light kit before they got me on board: two AlienBees B800s, 3 PocketWizard Plus IIIs, stands and umbrellas with a backdrop. I did some research and was going to shoot a clamshell set-up. So far so good, but when I unpacked the boxes to do a dry run, the umbrellas are silver reflective, not shoot through. Still managed to get reasonable light with about 1/8th power on top and 1/32nd on the bottom, but it's a bit harsh/contrasty. Given that the client is not going to spend any additional money, is there anything I can do, with what's on hand to improve the quality of the light? Is there a better set-up than clamshell, given my particulars? I'm an experienced shooter, but not so much with strobes.
Thanks,
Al
Specializing in Theatrical Photography. See my work at:
www.alfoote3photograph​y.com/ (external link)
www.facebook.com/alfoo​te3photography (external link)
mike_d
Jul 02, 2014 00:30 |  #2
Hang some diffusion fabric in front of the umbrellas.
whoty
Gallery: 20 photos
Joined Nov 2010
Jul 02, 2014 02:25 |  #3
Why clamshell for corporate shots? I would think something simple like Rembrandt should work. Try this. Get a white foam board. Main light at 45 degree on one side,poster board on the other used for fill. Use that second light as a rim.
I shot this for a real estate agent needing headshots for her business cards. In my example,I opted to use a gridded light onto the background instead of a rim light. Power was at it's lowest setting.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/07/1/LQ_689030.jpg
Image hosted by forum (689030) © whoty [SHARE LINK]
There is nothing worse than a brilliant image of a fuzzy concept. - Ansel Adams
Instagram (external link)
Facebook (external link)
AlFooteIII
Joined Jul 2013
Jul 02, 2014 05:12 |  #4
Thanks, both!
Snafoo
Gallery: 92 photos
Jul 02, 2014 06:53 |  #5
Ask to buy a couple of shoot- through umbrellas. They're only $25 each.
I agree that clamshell portraits aren't ideal for corporate, but I suppose that may depend on the end purpose, and also on the corporation. Why did you decide on the clamshell look?
http://www.jonstot.com​/ (external link)
BTNorris
Jul 02, 2014 12:37 |  #6
Snafoo wrote in post #17006822 (external link)
+1, but just eat the cost.
Get better/branded ones if you can and want, but if money is really an issue, how about $8 each, amazon prime:
http://www.amazon.com …2&keywords=flas​h+umbrella (external link)
7D, 17-55, 50 1.4, 70-200, 10-22, Kenko Tubes, OPTIX xr, Einstein
ksbal
Gallery: 374 photos
Best ofs: 9
Jul 02, 2014 13:02 |  #7
Yep, just got done doing a 3 light set-up which you can do with two lights if you use a reflector for fill. Ideal is to have a fourth light on the BG as a spot, but depends on if you want to spring for a small flash that has an optical trigger.
I wouldn't do clambshell - works on the gals, not so great for the guys, and you want a consistent look.
But I guess I'd like to see a clambshell of a 55-65yr old man... that'd be interesting.
By the by.. if you want to have less wrinkles, then the larger you want those umbrellas. I have a couple of 60inch bounce ones like the link below.. they throw wonderful soft light, but you want to watch the spill. Long conference room with a higher than 8 ft ceiling if you can.
http://www.adorama.com​/WEU60WB.html (external link)
Godox/Flashpoint r2 system, plus some canon stuff.
AlFooteIII
Joined Jul 2013
Jul 02, 2014 14:58 |  #8
Thanks to everyone for your suggestions.
We ended up going with what I described above but did add a speedlight on the background. It worked well -- about 75 - 80 people, give or take. There was only one guy and it looked pretty good on him, too! I certainly learned a lot and hopefully they learned to talk to the photographer before they rent the kit!
Now to the editing....
AlFooteIII
Joined Jul 2013
Jul 02, 2014 15:00 |  #9
Oh -- PS for the buy the 'brellas, eat the cost, unfortunately, I got to see the gear last night and had to start shooting early this morning. No chance to run to B&H or Adorama, much less Amazon. Like I said -- behind the eight ball!
2,022 views & 0 likes for this thread, 6 members have posted to it.
1039 guests, 115 members online
