Thread started 03 Jul 2014 (Thursday) 01:09
How to improve quality of exported images from LR?
p00kienrayray
Gallery: 24 photos
Joined Feb 2014
Jul 03, 2014 01:09 |  #1
Not hip on the nomenclature, but the low resolution to the left of the baby's head is horrendous. The original file in LR 5.5 looks good with no issues. When I export it to my PC, it shows up. Then when I upload to Flickr, it worsens and you see what we have here. Is there any way I can minimize this before I export? In LR, I cranked up the image quality to 100%, and messed with some other settings but no dice.
I'd like to export it as tiff or jpg to upload to flickr.
IMAGE: https://farm3.staticflickr.com/2936/14376767417_03837e7f97_c.jpg
IMAGE LINK: https://flic.kr/p/nUqG​5i  (external link) DSC00500 (external link) by cassy.samel (external link), on Flickr
Some cameras, some lenses
tonylong
...winded
Gallery: 60 photos
Jul 03, 2014 01:25 |  #2
I'm sorry, but I'm not sure what you are referring to here...? When you say "to the left of the baby's head", are you referring to the dark background to our (camera) left? Or to the dark/shadowed part of her face to our left?
Tony
p00kienrayray
Gallery: 24 photos
Joined Feb 2014
Jul 03, 2014 02:19 |  #3
It's actually both sides of the baby's head (more evident in the background). See the tonal effects?
bk2life
Gallery: 18 photos
Joined Nov 2010
Jul 03, 2014 02:38 |  #4
can you screen print it in LR so we can see the before and after(ish) for comparisons?
-james
5Diii|7D|Nifty 50|Canon 17-55mm-2.8|Canon 70-200L 2.8 IS ii|2x 600EX-RT|ST-E3-RT|CS6
cdifoto
Don't get pissy with me
Jul 03, 2014 03:08 |  #5
I think you're just being too obsessive for the web. No one will want to download a file big enough to eliminate the problems you're referring to (compression artifacts) in order to view it. Concentrate on getting your exposures more correct. Unless of course you underexposed this one intentionally.
frugivore
Gallery: 11 photos
Jul 03, 2014 03:24 |  #6
cdifoto wrote in post #17008830 (external link)
The underexposure is what's causing the color banding. Here's the same pic with exposure increased (and black point moved for contrast):
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/07/1/LQ_689087.jpg
Image hosted by forum (689087) © frugivore [SHARE LINK]
Of course, the shadows fall apart since it's not from a D800. :)
tzalman
Fatal attraction.
Jul 03, 2014 03:31 |  #7
I do see the banding you are (apparently) referring to. There are also some other problems. It is in Adobe RGB, which means it will not be seen properly by viewers unless they are using a color managed browser and profiled monitor. Export it in sRGB.
Also, it is (to my taste) too saturated. I would reduce saturation by 25%. And lighten it a bit more than you already have (although it's hard to say how much without knowing the child's ethnicity.)
As to the banding: unless the A7 has serious low light problems, it was caused by your processing. My guess would be excessive lightening of an underexposed 8 bit image. But it can be only a guess because your posting has neither Exif nor XMP metadata so we can't know how it was shot and processed and so can't say what to do differently. My suggestion would be to make the original Raw available.
Elie / אלי
frugivore
Gallery: 11 photos
Jul 03, 2014 03:43 |  #8
tzalman wrote in post #17008841 (external link)
How can you tell that it's in aRGB? Did you just compare in both a color managed and non-color managed browser?
tzalman
Fatal attraction.
Jul 03, 2014 04:55 |  #9
frugivore wrote in post #17008844 (external link)
First I copied to clipboard the photo location URL and opened Jeffrey Friedl's on-line Exif viewer http://regex.info/exif​.cgi (external link)
which gave me the embedded color space. Then I saved the image to my Desktop and opened it in PS which confirmed the space. I converted it to sRGB, opened Levels and set the color balance from one of the white polka-dots, white point to the specular highlight in the left eye, black point to the darkest spot between the folds of whatever that is in front of her, and brightened the gamma to -1.30. Then I reduced saturation by -30 and got this:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/07/1/LQ_689089.jpg
Image hosted by forum (689089) © tzalman [SHARE LINK]
Elie / אלי
BigAl007
Gallery: 556 photos
Jul 03, 2014 05:09 |  #10
I would think moving from AdobeRGB to sRGB as your colour space will also help you a lot. Viewing AdobeRGB images on a non colour managed browser will leave your images looking dark and muddy, even before any issues caused by the image being underexposed.
Remember also that the standard Windows image viewing application on most PC's is also not colour managed. So you will see the issues when simply looking at an exported image from within Windows.
Alan
p00kienrayray
Gallery: 24 photos
Joined Feb 2014
Jul 03, 2014 09:16 |  #11
john crossley wrote in post #17008930 (external link)
Quite suppressed that no one had thought about sharpening the image.
Levels adjustment: Desaturation: USM
HOSTED PHOTO DISPLAY FAILED: ATTACH id 689090 has been deleted. ]
I sharpened only the face. Maybe I should sharpen the background? That's where the color banding is.
Yes, it was under exposed intentionally--or rather I darkened the background on post.
I actually didn't lighten anything. I darkened most of the photo.
BigAl007 wrote in post #17008884 (external link)
Alan
It was originally srgb but it provided the same results.
p00kienrayray
Gallery: 24 photos
Joined Feb 2014
Jul 03, 2014 09:21 |  #12
I can't really see the details in your pic too well on my smart phone. Is the color banding reduced?
p00kienrayray
Gallery: 24 photos
Joined Feb 2014
Jul 03, 2014 09:29 as a reply to  @ p00kienrayray's post |  #13
Here's a shot of the paint brush settings for the background. Please let me know what i may have done wrong. As you can see, the color banding and the fringing on the left side of face is not there pre export.
IMAGE: https://farm3.staticflickr.com/2917/14559780691_535dfeede6_c.jpg
IMAGE LINK: https://flic.kr/p/obAF​xz  (external link) Capture (external link) by cassy.samel (external link), on Flickr
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jul 03, 2014 10:01 |  #14
If you use AdobeRGB, you must use it from start to finish AND THEN convert within your AdobeRGB workspace to sRGB before uploading to your hosting site.
If LR set to AdobeRGB and is outputting an AdobeRGB file into PS and you are using sRGB there, you will have a problem immediately on opening in PS. So I'd check all these settings, decide on a color space, and stick with it in camera, in LR and in PSCS.
Just to clarify, AdobeRGB is NOT the problem. However, misuse or inconsistent settings could be. It can be quite a pain to keep it all straight, which is part of why people say "keep it simple and use sRGB"
just FYI I tend to stay with AdobeRGB all the way through.
CDS' HOT LINKS
NullMember
Jul 03, 2014 13:42 |  #15
bannedPermanently
p00kienrayray wrote in post #17009205 (external link)
Well, to be absolutely honest with you, I can't see anything wrong with the original image you posted, apart from the fact that it needs sharpening.
4,508 views & 0 likes for this thread, 10 members have posted to it.
1452 guests, 132 members online
