I would like to set up a monitor on a 3 axis wireless gimbal. I would like to connect it to my 5d with a wireless receiver.
What setup do you recommend? Which one you don't?
Thanks so much!
oharing Senior Member 564 posts Likes: 23 Joined Apr 2010 Location: Miami, FL More info | Jul 03, 2014 06:45 | #1 I would like to set up a monitor on a 3 axis wireless gimbal. I would like to connect it to my 5d with a wireless receiver.
TTGator Senior Member 649 posts Joined Aug 2007 Location: High Point, NC More info | Jul 03, 2014 12:53 | #2 Do you mean a 3-axis brushless gimbal? Haven't heard of any wireless monitor setups, so I can't help you with that. 5DII & 5DIII | 85 F1.8 | 100mm F2.8 Macro | 16-35 II L | 35L | 24-105 F4L [COLOR=black]| 70-200 F2.8 IS L | Speedlite 540EX | AB800(x4) | Manfrotto 561BHDV Monopod |
skwirnmn Goldmember 1,058 posts Likes: 1 Joined Aug 2011 More info | Jul 05, 2014 13:50 | #3 Works fine for dslr since it's HDMI. I'd recommend a cable pinch since HDMI is the worst connection known to man.. it'll fall out if you even look at it wrong, so it'll definitely be susceptible to disconnecting on a movi.
TTGator Senior Member 649 posts Joined Aug 2007 Location: High Point, NC More info | Jul 09, 2014 12:22 | #4 Good Lord that's cool but expensive. Why would you want to pull a full 1080 feed wirelessly unless you were live streaming though? It would be a waste for any normal field monitor of 720p or less. 5DII & 5DIII | 85 F1.8 | 100mm F2.8 Macro | 16-35 II L | 35L | 24-105 F4L [COLOR=black]| 70-200 F2.8 IS L | Speedlite 540EX | AB800(x4) | Manfrotto 561BHDV Monopod |
bscenefilms Member 36 posts Joined Jul 2014 More info | Jul 15, 2014 08:58 | #5 The industry standard for this is the Teradek
InterMurph Senior Member 253 posts Joined Nov 2011 Location: Gloucester, Massachusetts More info | Jul 16, 2014 12:33 | #6 You didn't specify the application. If it's not a demanding one, you might be able to use the CamRanger ($300)
Jul 21, 2014 16:26 | #7 InterMurph wrote in post #17035740 You didn't specify the application. If it's not a demanding one, you might be able to use the CamRanger ($300) The motors are slow, and the up/down range isn't great. But it's fully integrated into the CamRanger system, which I love. And it's perfect on the second camera I use for my kids' piano recitals. I was also going to suggest the Camranger, but the $40 DIY version that uses the same exact hardware (A TP-Link MR3040 Wifi router) without the branding. You download a free firmware patch then use an Android device with the DSLRContrller app ($6). the delay is negligible and seems to work very well. I have this setup, but haven't had a chance to test it out very much. -Jayson- my flickr
InterMurph Senior Member 253 posts Joined Nov 2011 Location: Gloucester, Massachusetts More info | Does the DSLR controller app control the motorized tripod head?
Jul 21, 2014 17:14 | #9 InterMurph wrote in post #17046705 Does the DSLR controller app control the motorized tripod head? I tried the DSLR controller app and found it to be incredibly buggy, and not worth the hassle. I have found the CamRanger to be very very very reliable. Maybe the DSLR controller app has improved, but I didn't have the patience for that. He's talking about using this just as a transmitter on a Movi-style handheld gimbal, not a pan/tilt head. -Jayson- my flickr
Headshotzx Goldmember 4,488 posts Likes: 141 Joined Dec 2007 Location: Singapore More info | Jul 24, 2014 13:08 | #10 |
TTGator Senior Member 649 posts Joined Aug 2007 Location: High Point, NC More info | Jul 28, 2014 15:19 | #11 Just saw this link: 5DII & 5DIII | 85 F1.8 | 100mm F2.8 Macro | 16-35 II L | 35L | 24-105 F4L [COLOR=black]| 70-200 F2.8 IS L | Speedlite 540EX | AB800(x4) | Manfrotto 561BHDV Monopod |
TTGator Senior Member 649 posts Joined Aug 2007 Location: High Point, NC More info | Jul 29, 2014 08:14 | #12 Well I just learned one limitation of the Nyrius... You cannot broadcast from one transmitter to multiple receivers. At least not natively. You would have to hook the receiver to an HDMI splitter. I believe the Arrow allows for multiple receivers and therefore multiple monitors which is an advantage. 5DII & 5DIII | 85 F1.8 | 100mm F2.8 Macro | 16-35 II L | 35L | 24-105 F4L [COLOR=black]| 70-200 F2.8 IS L | Speedlite 540EX | AB800(x4) | Manfrotto 561BHDV Monopod |
TTGator Senior Member 649 posts Joined Aug 2007 Location: High Point, NC More info | Jul 29, 2014 11:21 | #13 Ok, this is getting interesting the more I research this... Since I'm getting the DJI Ronin it will be very nice to be able to go wireless. Just trying to find a cost effective way to do it while keeping as many options open as I can. Here is my current thinking: 5DII & 5DIII | 85 F1.8 | 100mm F2.8 Macro | 16-35 II L | 35L | 24-105 F4L [COLOR=black]| 70-200 F2.8 IS L | Speedlite 540EX | AB800(x4) | Manfrotto 561BHDV Monopod |
TTGator Senior Member 649 posts Joined Aug 2007 Location: High Point, NC More info | Aug 01, 2014 17:52 | #14 Ok, I made my decision... went with the WeyeFeye. Here's a quick review I did today if anyone is interested in a setup with a monitor on your camera rig with a second wireless monitor. 5DII & 5DIII | 85 F1.8 | 100mm F2.8 Macro | 16-35 II L | 35L | 24-105 F4L [COLOR=black]| 70-200 F2.8 IS L | Speedlite 540EX | AB800(x4) | Manfrotto 561BHDV Monopod |
Sep 02, 2014 10:22 | #15 steelbluesleepr wrote in post #17046739 He's talking about using this just as a transmitter on a Movi-style handheld gimbal, not a pan/tilt head. exactly!
| Latest registered member is semonsters 1039 guests, 115 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
