Thread started 17 Jul 2003 (Thursday) 17:49
First mistake (well maybe)
Hatem ­ Eldoronki
Joined Jul 2003
Jul 17, 2003 17:49 |  #1
I unmounted my 75-300 and put on the 28-135, all without thinking that the camera was on! Now I'm all worried that something is not working right..
Does anybody know if the camera should've been turned off when lenses were un'screwed'? Or am I 'screwed'? (Nothing in the manuals mentions anything of the sort anyways.)
1 D s M k I I
(Gear List Here)
 (external link)
barnold999
Joined Apr 2003
Jul 17, 2003 18:00 |  #2
You should be fine... I always switch lenses with it on.
daveh
Joined Apr 2003
Jul 17, 2003 18:12 |  #3
I have a Canon film SLR (T90) that I've NEVER turned off (except for battery changes) since I bought it about 10 years ago. Of course, that's a different lens mount, but basically, don't worry about it. They expected that when they designed it.
robertwgross
Joined Nov 2002
Jul 17, 2003 18:20 |  #4
I think it would be slightly safer to switch off the camera before swapping lenses. However, I have swapped many times without that precaution, and I haven't seen a problem.
I also try to switch off the camera before swapping CF cards. Probably 99% chance that this has no effect, but the camera is so expensive I kind of hate to leave everything to chance.
---Bob Gross---
Guillermo ­ Freige
Joined Jun 2003
Jul 17, 2003 18:50 |  #5
mcouper:
Don't worry. Canon recommends to NOT to switch lenses with the camera on (at least in my EOS 5 manual), but I've never had a problem and I've forgotten to switch it off a LOT of times :)
Guillermo
EOS 5D MkII, 40D and 20D owner.
EF 17-40L, 24-105L IS , 70-300 IS, 24 f2.8, 35 f2, 50 f2.5 Macro, 85 f1.8.
EF-s 18-55 IS. Sigma 12-24, Tamron 17-50 Di II
MateoV
1 post
Joined Jul 2003
Jul 20, 2003 17:20 |  #6
Nothing to worry about, although I wouldn't make a habit of it. I believe Canon recommends turning the camera off first because the image sensor has a slight static charge while on which can attract dust.
NILOLIGIST
Joined Jan 2003
Jul 20, 2003 21:46 |  #7
Well, on another note. I somehow opened my CF card door while the camera was on and nothing happened. I closed the door turned off the camera and turned it back on again, no problems...
I won't be trying it again.
NiL,
Canon 1D Mark II, 24-70 f/2.8L, 17-40 f/4L, 70-200 f/2.8L. 580EX, 4 - Alien Bees, Gitzo Tripod, Bogen Monopod.
My websites
http:// (external link)www.frederiqueporter.c​om (external link)http://www.musecube.co​m/photosbyrica (external link)http://www.pbase.com/n​iloligist (external link)
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jul 20, 2003 22:15 |  #8
I have done both dozens of times.
Here are the issues with both "mistakes"
1. Swapping lenses with the Camera on:
THE GOOD: This won't hurt the camera.
THE BAD: There is a reason NOT to do this though. With the camera powered up,. the CMOS is charged,. and the static will make it more likely to attract any dust that may happen into the open lens mount.
BOTTOM LINE: Don't fret if you forget,. but do try not to :)
2. Opening CF Dor with Camera on
THE GOOD: This probablywon't hurt the camera.
THE BAD: If you do this while the Camera is WRITING to the CF card YOU WILL LOOSE IMAGES,.. you may lock up the camera,. and may damage the CF. (unlikely)
BOTTOM LINE: Try to avoid this one!
DO NOT open the CF Door while the Camera is writing to the card! This would be bad :(
CDS' HOT LINKS
Mark0159
I say stupid things all the time
Gallery: 45 photos
Joined Mar 2003
Jul 20, 2003 22:30 |  #9
re: one thing not to do
even tho this happened on a Casio slim camera the guy had for 30 mins.
take a photo while opening the battery door, the camera now comes up with System Error and has to back to Casio for repair.
Well this happened to today, with a work mates new camera, just my luck.
I am a good chap however I did offer to pay for the repair if there is any.
The best thing to do with a camera, don't be in so much of a hurry with the dam thing.
Mark
https://www.flickr.com​/photos/52782633@N04 (external link)
Canon EOS 6D | Canon EF 24-105mm f/4L IS USM, EF 17-40mm f/4L USM, EF 50mm f/1.4 USM, EF 100mm f/2.8 Macro USM | Tamron SP 35mm F1.8 Di VC USD | Canon Speedlite 550EX -|- Film | Canon EOS 3 | Olympus OM2 | Zuiko 35mm f2
Longwatcher
obsolete as of this post
Joined Sep 2002
Jul 21, 2003 09:46 |  #10
Should cause no damage to camera, but with my D60 I have lost a few images because of leaving the camera on when I switched lenses. Have not experienced same with 10D, but then I am much better about switching lenses with camera off. Only happened occasionally in any case.
"Save the model, Save the camera, The Photographer can be repaired"
www.longwatcher.com (external link)
1DsMkIII as primary camera with f2.8L zooms and the 85L
http://www.longwatcher​.com/photoequipment.ht​m (external link)
2,239 views & 0 likes for this thread, 10 members have posted to it.
1722 guests, 112 members online
