Thread started 05 Jul 2014 (Saturday) 13:52
Lightroom Mask Brush Question
sancho1983
Jul 05, 2014 13:52 |  #1
I'm using Lightroom 5.
I sometimes use the mask brush to 'whiten' the background of a high key type studio shot, I'm sure in the past I didn't have to be that accurate near the edges as it sort of 'recognised' a bit that was white rather than the subject. In fact I distinctly remember that if I hovered the crosshair in the middle of the brush over a 'white' bit and clicked the mask would only be applied to the bit of the brush that was the same colour, generally leaving the subject as it was.
It no longer does this though.
Have I imagined this? Or have I just changed a setting or something? I'm not even sure what I could Google to find the answer so thought I would try here!
Thanks in advance
Instagram (external link)
Https://bgsweddings.co​.uk (external link)
Snowyman
Gallery: 682 photos
Joined Oct 2011
Jul 05, 2014 14:48 |  #2
check "auto mask" box.
Snowy's Gear
Deviant Art (external link)
500px (external link)
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Jul 06, 2014 03:31 |  #3
Yep towards the bottom of the Mask panel is a check box.
In case you didn't know you also have an A brush a B brush and an Erase brush. The A & B brushes can be set up with different settings so that you just switch between brushes to select the different settings (mask on, mask off).
Dan Marchant
sancho1983
Jul 06, 2014 05:26 |  #4
Thanks, I'll give that a go, it was driving me insane!
BigAl007
Gallery: 556 photos
Jul 06, 2014 12:57 |  #5
Hitting the A key will toggle it on and off too. This can make it easy to switch without realising.
As a side note, due to the way that the brush choses the colour that is selected sometimes you can get a spattered effect as you paint if the subject has a lot of texture. In this case it is often better to go over the egde of what you want selecting. Then you can use the erase brush with the auto mask to erase beck to the edge.
Alan
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Jul 07, 2014 02:37 |  #6
BigAl007 wrote in post #17014731 (external link)
Big + 1 to this. It is a very useful tip.
Also, just in case you aren't au fait with the keyboard controls yet, pressing/holding the ALT key will switch the brush from Paint to Erase. Very handing when trying to make detailed adjustments and needing to switch back and forth.
Lastly, if you are having trouble getting a good edge it can often be very helpful to adjust the Feather and Flow of the brush. The reduced strength and opacity of the brush means that you can create a gentler transition and it doesn't matter as much if you go over the edge.
Dan Marchant
sancho1983
Jul 07, 2014 04:11 |  #7
Thanks. Yea, I must have pressed A accidentally.
nathancarter
Gallery: 32 photos
Jul 07, 2014 11:52 |  #8
Alan
Another vote for this method.
Brushing on, don't try to be super accurate.
Brushing off, use Auto Mask and get as accurate as you can.
Auto Mask when applying the mask will very often leave a splotchy pattern which is almost invariably undesirable.
1,562 views & 0 likes for this thread, 5 members have posted to it.
1065 guests, 104 members online
