Thread started 08 Jul 2014 (Tuesday) 10:06
Ready to replace "disposable" umbrella & Stand
NewCreation
Gallery: 47 photos
Joined Jan 2013
Jul 08, 2014 10:06 |  #1
So to start off learning lighting I bought a super cheapo set off ebay. Two stands, two umbrellas, two continuous light sockets (lol-yeah...never used those), & bag for less than $30. They were a good learning tool to see if I really wanted to get into using off camera light. But alas, they are CHEAP! And I want something more sturdy/durable.
Now it's time to buy grown up stuff but I am not sure which are good and don't have a local store near enough to me to take a look a stuff before purchasing.
Looking for some input from those you have first hand experience with different brands.
Is Wescott good for umbrellas/modifiers?
How about this stand set? http://www.amazon.com …/ref=cm_cr_pr_p​roduct_top (external link) The reviews are good but perspective has big influence on everything.
Or should I just get stands like these? http://www.amazon.com …XLJ&coliid=I1HZ​GRZZGKIFHY (external link)
Thanks for your input!
My name is Brenda ~Saved by grace, walking by faith
http://brendahoffmanph​otography.com (external link)
Facebook (external link)
ksbal
Gallery: 374 photos
Best ofs: 9
Jul 08, 2014 11:34 |  #2
On the stands... I hate the lever style.. I had no trouble with the first, then the second one decided not to work -- the nuts come loose or something - I'd tighten and then it would come loose again. At all the wrong times - this last time I had Hubby do it and it has stayed, but I would advise against them for a stand that is the regular twist till tight type (where the sections extend)
I have a back drop stand of these:
http://www.amazon.com …103&sr=1-9&keywords=linco (external link)
and I really like them, heavy and quality, but they also have a big footprint... good thing, bad thing.
I can say try for the 10ft ones... 7-8 ft isn't enough many times. (although one shorty for a bg light is helpful)
I'm sure others will post some good ones here shortly.
Godox/Flashpoint r2 system, plus some canon stuff.
sportmode
Joined Nov 2010
Jul 08, 2014 13:30 |  #3
A little more expensive, but I like the Cheetahstand, especially since I tend to move it around quite a bit for events...
https://www.cheetahsta​nd.com/Cheetah-Stand-C8-p/c8.htm (external link)
5D Mark III, 6D, EOS-M 22mm f/2 | 24-70mm f/2.8L II | 50mm f1.4 | 100L | 70-200mm f/2.8L IS II | Rokinon 8mm Fisheye
nathancarter
Gallery: 32 photos
Jul 08, 2014 14:28 |  #4
I have light stands similar to the PBL ones that you linked, though mine are the 7-foot and not the 10-foot. I like them. For the price, they're great. I also have 10-foot Manfrotto stands that came in a kit with Elinchrom studio lights.
I prefer the lever-style locking collar. Sure, it DOES need occasional adjustment - but it's faster and easier than the knob-style collars; more importantly, I have a habit of locking down the knob-style collars so tight that my assistant/wife can't loosen them. The lever-style eliminates that problem.
Westcott has a pretty good reputation for inexpensive modifiers. Fotodiox also is pretty good stuff for the price. You can spend more to get better, and you can spend more to get worse.
PLLphotography
with the TF
Jul 08, 2014 14:30 |  #5
I have a couple of the PBL stands, and they've worked for me and held up well for the last 3 years.
I used to have a Cheetah Century light stand/boom combo, but it was heavy, and not very compact.
I sold it and eventually got one of these Cowboy Studios (don't laugh....) combination light stand/booms, and it's actually quite nice for the price. use it as a light stand, use it as a boom.
http://www.amazon.com …ohs_product?ie=​UTF8&psc=1 (external link)
added bonus that it folds up like a normal light stand.
as for umbrellas, I use Westcott, although I hear Impact is great as well. +1 for Fotodiox. I've owned some of their EZ Octobox softboxes as well as beauty dishes and they are great.
Phillip - phillipwardphotography​.com (external link) | Instagram (external link) | Donate to POTN
NewCreation
Gallery: 47 photos
Joined Jan 2013
Jul 08, 2014 16:04 |  #6
ksbal wrote in post #17018878 (external link)
Thanks for the input. I didn't really think about the footprint. It does make sense to consider it.
sportmode wrote in post #17019075 (external link)
I move around a bit, too, so I will look into those.
nathancarter wrote in post #17019190 (external link)
Nathan - What are the better light modifiers? I'd like to look into them. Like I said, I don't know what's what in this area yet,
Also, you make a great point about the levers on the lightstand. I recently assisted at a wedding and was having a bugger of a time trying to adjust the lightstands because I didn't have the grip strength.
PLLphotography wrote in post #17019196 (external link)
Phillip - I like the looks of that boom! I am not opposed to budget stuff if it works!
Thanks for a couple more names of modifiers to check into.
nathancarter
Gallery: 32 photos
Jul 08, 2014 17:26 |  #7
NewCreation wrote in post #17019342 (external link)
Ohhhh, that's a tough question. Depends on your style, and what you shoot, and what lights you're modifying.
For basic portraits for a novice, you just want something to make the light bigger.
Generally, bigger+closer = softer light, which is usually desirable for most standard types of portraits.
Smaller+farther = harder light (crisper shadow edges), which can make good portraits with a little practice.
There's way more to it than that, of course.
I usually prefer a softbox or a brolly-box style umbrella, over a shoot-through umbrella. The brolly box gives less rapid falloff, more wrap light, and less of a center hotspot. The shoot-through gives a center hotspot and more spill. Both modifiers have their uses.
When shooting with Speedlights, these brolly boxes are my go-to modifiers:
http://www.amazon.com …/B001BSQK8Q/ref​=pd_cp_p_2 (external link)
You'll need an umbrella adapter to mount them to the stand & speedlight. I have a couple of the Manfrotto 026 which is by no means the only option.
Those aren't the "better" modifiers. They're cheap and almost disposable, but they work well. If you don't know what you need, start out with those until you figure out what you do need.
Tons of other things out there. Beauty dish, stripbox, grids, snoots, reflectors. You don't need a ton of expensive equipment to get a nice portrait. However, having a bunch of different tools on hand will give you more options when you need to change up your lighting style, for a different portrait look or a different type of subject.
I don't have any expensive modifiers. I'm not at the point where "more stuff" would significantly improve my results (or make me any more money). My most expensive modifiers are a Elinchrom Maxilite and a medium-sized Fotodiox strip box with an Elinchrom speed ring. A second strip box would be nice some days... but then I would need another strobe head for the main light, and a modifier to put on it, and and and and and .. And my budget doesn't allow for a case of G.A.S. right now.
Seamus69
Joined Nov 2010
Jul 08, 2014 18:13 |  #8
The first question you need to address is how much weight are you going to lift (light + modifier) and how high? Your answer will dictate how sturdy your stand needs to be.
Canon 60D, 5Diii, 24-105, 24-70ii, 70-200 f2.8 ii is, 580ex, (2)430ex
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Jul 08, 2014 19:36 |  #9
Heya,
I found that inexpensive Impact stands are fantastic. I just toss a sandbag at the base and it holds everything I throw at it. I bought an inexpensive Fotodiox boom extension for holding reflectors for natural light use, as well as the top of the stand still accepting mounts for lite and modifiers. I like the neweer 24" x 24" softbox that takes speedlites, very portable, and produces wonderfully soft light. Westscott umbrellas are fantastic, I like the 43" ones, great for shoot through and for bounce.
It comes down to budget, portability (if needed), and how many lights you want to actually run.
Here's some good portable modifiers to consider:
SMDV 60 (portable softbox) (external link)
Neweer 24x24" portable softbox for speedlites (external link)
(They're the same thing essentially, one is just a little nicer, but produce nearly the same light)
Westscott 43" umbrella with black cover (bounce) (external link)
Westscott 43" umbrella, white shoot through (external link)
I tend to use two lights. One with a softbox or umbrella. And one that is just on a stand with a honeycomb grid to do hair, etc from behind.
Very best,
PLLphotography
with the TF
Jul 08, 2014 19:41 |  #10
I forgot to mention, when I'm out and about, I also use the following combination:
Monopod with light stand adapter with a Phottix multi-boom attached that allows me to use 2 flashes
Phottix double folding shoot through umbrella. 33" umbrella but folds down to like 15"
Radio triggers
I can hand hold the monopod in my left hand, and shoot with my right.
Not necessarily what you are looking for, but I find it useful for "run and gun". :)
Alveric
Gallery: 38 photos
Jul 08, 2014 19:56 |  #11
Can't go wrong with these: http://www.bhphotovide​o.com …AC_Alu_Air_Cush​ioned.html (external link)
The air cushioning is really nice: both your fingers and your flash will thank you for it. Those are stackable (they sell them in 3-pack as well) and easy to carry. That's the first stand I bought and it has served me extremely well. The only thing I don't like is that it's too long to fit into my rolling case.
NewCreation
Gallery: 47 photos
Joined Jan 2013
Jul 08, 2014 19:59 |  #12
nathancarter wrote in post #17019503 (external link)
Sorry for such a broad question! I am shooting events (weddings) and portrait sessions (a ton happen to be on a windy beach because of my location). So I think I may have to really put some thoughts into my plan of attack.
Seamus69 wrote in post #17019593 (external link)
This is true.
MalVeauX wrote in post #17019757 (external link)
Heya,
Very best,
Thanks for the links. Those help a lot. I am working with speedlights and want to stay that way for now. I was looking at the wescott 43" recently so it's good to see it pop up in this thread.
PLLphotography wrote in post #17019762 (external link)
Radio triggers
So glad you replied with this! I will have to see if I can pull something like that together as I am often shooting alone and at the beach where a lightstand is just not practical.
Alveric
Gallery: 38 photos
Jul 08, 2014 20:12 |  #13
If you're shooting in windy locations, you might consider a C-stand instead: because of their flat legs, they're easier to 'sandbag' and it's less easier for passers-by to trip on them. They're also sturdier (which can be a disadvantage too, because they're slightly heavier) and thus withstand the wind better, especially if you're using brollies. Avenger and Matthews are the brands to go for if you consider these. They also accept booms. In fact, there's a boom kit: http://www.bhphotovide​o.com …BKIT_Century_C_​Stand.html (external link)
NewCreation
Gallery: 47 photos
Joined Jan 2013
Jul 08, 2014 20:16 |  #14
Alveric wrote in post #17019822 (external link)
Very interesting! I shoot at the beach quite often. I wonder how it'd like the sand getting in the joints.
Alveric
Gallery: 38 photos
Jul 08, 2014 20:29 |  #15
Quality stands can be disassembled easily, so they should be easy to clean. This is another boon: if you bend the legs, you don't have to throw away the stand, you can just order the replacement part from the vendor.
2,572 views & 0 likes for this thread, 8 members have posted to it.
875 guests, 162 members online
