Thread started 15 Feb 2006 (Wednesday) 21:22
Canon 20d and flash sync mode
gplracer
Joined Nov 2005
Feb 15, 2006 21:22 |  #1
Why is it that I get better results in AV mode when the flash sync on my Canon 20D is on 1/250th second instead of the default auto? When on auto the pictures are under developed when using the built in flash.
Canon 50D
18-55 kit lens
70-200 f4 L lens
Tamron 28-75 f2.8
Canon 580EX
tim
Light Bringer
Feb 15, 2006 21:45 |  #2
If you want definitive answers you need to post examples in both modes. The pictures should contain EXIF information, which will tell us what the camera's done. I don't use auto modes so I have no idea what it does in those modes.
In Av the camera meters for the background and uses the flash as fill. You should try manual mode, say ISO400, F5.6, 1/250th, then F2.8, 1/50th, and take a look at the difference. ETTL does the work there.
cdifoto
Don't get pissy with me
Feb 15, 2006 21:47 |  #3
That's your camera's way of saying "get a friggin external flash on me, I'm naked!"
SkipD
Joined Dec 2002
Feb 16, 2006 06:35 |  #4
In my opinion, the built-in flash is totally useless. You will have MUCH better results with one of the EX series Speedlites.
It is particularly important to get one of the models that can swivel and tilt to allow bouncing off the ceiling, walls, or reflectors that you put into position. Some of the older (and cheaper models) don't/didn't have the total swivel and tilt capability.
Skip Douglas
Jon
Joined Jun 2004
Feb 16, 2006 12:15 |  #5
Probably because normally it's using the flash to fill in a bit on the available light exposure, but when you're using that CF (3-1?) it's been told that it won't be getting available light, so it makes the flash primary.
Jon
Cocker Spaniels
tim
Light Bringer
Feb 16, 2006 15:32 |  #6
I find the built in flash ok if all I need is a bit of fill, it's a bit harsh but ok if I don't bother to take along an external flash - eg to a party. I almost always take a flash though, the 580 is so much more versatile.
gplracer
Joined Nov 2005
Feb 17, 2006 08:42 as a reply to  @ tim's post |  #7
Thanks for the responses. It just seems that when indoors things are a bit underexposed if I use "auto" flash sync under custom functions while using AV mode. I borrowed a friend's 420ex and got the same results. Granted this is in a room that has a low light level.
Canon 50D
18-55 kit lens
70-200 f4 L lens
Tamron 28-75 f2.8
Canon 580EX
Wilt
Feb 17, 2006 09:23 |  #8
>>It just seems that when indoors things are a bit underexposed if I use "auto" flash sync under custom functions while using AV mode. I borrowed a friend's 420ex and got the same results<<
Very typical and widely spread complaint when using Canon ETTL flash as primary source of light. General wisdom to overcome this inadequacy of the ETTL implementation is merely to dial in FEC = 2/3EV or 1 EV, and 'learn to cope'.
tim
Light Bringer
Feb 17, 2006 15:10 |  #9
White or light walls in most homes will cause ETTL to underexpose by a stop or so.
3,838 views & 0 likes for this thread, 6 members have posted to it.
1190 guests, 122 members online
