Thread started 16 Feb 2006 (Thursday) 09:20
standard 20D flash
Yella ­ Fella
Feb 16, 2006 09:20 |  #1
didnt really noticed it but is there anything in the options to tone down the flash level of the standard flash on my 20D? Seems whenever i use flash indoors, things come out a shade of blue :confused:
Ed - www.edwardlui.co.uk (external link) | modelmayhem (external link) | facebook (external link)
Canon EOS 5D x2 | Canon EF 35mm f1.4 L USM | Canon EF 50mm f1.2 L USM | Canon EF 85mm f1.2 mkII L USM | Canon EF 24-70mm f2.8 L USM | Canon EF 70-200mm f2.8 IS L USM |Canon 580EX mkII x2http://www.edwardlui.c​om (external link)
TeeJay
Joined Jun 2005
Feb 16, 2006 09:22 |  #2
Sounds like a White Balance issue. Could you post an example?
1DsMkIII | 1DMkIIN | 70-200 f/2.8L IS | 24-70 f/2.8L | 24-105 f/4L IS | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 430EXII | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea :confused:
Yella ­ Fella
Feb 16, 2006 09:27 |  #3
havent got any on the net as of yet as im at work. I assumed it was to do with the WB, but what about setting the level of flash lower to a more subtle fill flash mode?
cmpowell125
Feb 16, 2006 09:32 as a reply to  @ Yella Fella's post |  #4
You can change the flash exposure bias by presing the right hand button (next to Drive-ISO) on the top of the camera (above LCD), you can then use the back dial to change between -2 and +2. If you look on the LCD you can see what it is set to.
Hope this helps.
Chris
Chris
1D MkIV
¦2 x 1D MkII
¦2x Canon 20D + Grip ¦Canon 24 - 70 F2.8 L ¦Canon 100 - 400 4.5-5.6 L ¦Canon 70-200 F4 L ¦ Canon 17-40 F4 L¦ Canon EF 50mm f/1.8¦ Canon EF 100mm Macro f/2.8
Wen: www.chrispowellphotogr​aphy.com (external link)
C&C always welcome.
TeeJay
Joined Jun 2005
Feb 16, 2006 09:36 |  #5
I think what you refer to is FEC (Flash Exposure Compensation) - in which case press the right-most button on top of the camera, and you will see a smaller version of the normal exposure compensation appear in the viewfinder. Then, using the wheel on the back of the camera - turn to the left decreases exposure and to the right, increases exposure. Would help though if we could "see" your problem :-)
Remember that the amount of compensation remains in effect even after you have switched the camera off and back on again.
cmpowell125
Feb 16, 2006 09:56 as a reply to  @ TeeJay's post |  #6
Almost got the right word. yeah, compensation was what I meant. I was drawing a blank when trying to think of the name.
Chris
1D MkIV
¦2 x 1D MkII
C&C always welcome.
TeeJay
Joined Jun 2005
Feb 16, 2006 10:21 as a reply to  @ cmpowell125's post |  #7
Sorry if it looked like I was correcting you, but I certainly wasn't. I hadn't seen your reply - we must have typed our responses at the same time.
I was simply referring to the original posters "description" of the lighting that he/she wanted to correct. Sorry if it came across that way:)
cmpowell125
Feb 16, 2006 10:24 as a reply to  @ TeeJay's post |  #8
No, i didnt take it the wrong way. Sorry didnt mean to imply that. I just couldnt think of the word i was after when posting.
Chris
1D MkIV
¦2 x 1D MkII
C&C always welcome.
TeeJay
Joined Jun 2005
Feb 16, 2006 10:26 |  #9
No worries, cheers Chris ;-)a
Yella ­ Fella
Feb 17, 2006 04:40 |  #10
thanks guys, i never knew you could actually change the level of the flash on the 20D, will try it this weekend :)
tim
Light Bringer
Feb 17, 2006 05:01 |  #11
Look up FEC (flash exposure compensation) in your manual, easy stuff :)
Yella ­ Fella
Feb 17, 2006 05:29 |  #12
i must be blind tim, im sure i couldnt find anything with regards to lowering the level of the flash on my cam... will have to try next week then as my manual is at home :)
but on a quick crash course, i have to switch flash on, then half depress the shutter release and turn the big dial at the back to reduce flash?
ds06
Joined Feb 2006
Feb 17, 2006 05:42 |  #13
I was aware of the FEC (Flash Exposure Compensation), but assumed this is more to do with changine shutter speed or aparture (in the same way that exposure compensation works in non-flash mode) rather than to do with reducing the power of the flash itself. Am I correct?
EOS 20D
Glass: Canon EF 50mm 1.4 · For Sale Sigma EX 15 – 30 mm · Canon EF 28 – 105 USM
Bits: 430 EX · BG-E2 grip · Tripod · Shutter Release RC
TeeJay
Joined Jun 2005
Feb 17, 2006 05:56 as a reply to  @ Yella Fella's post |  #14
Take a look at Page 96 of your manual.
Something that ahdn't been mentioned (although its covered in the manual) is that your on/off switch should be at it's "second click" (just past the ON mark).
Then press the right-most button on the top of the camera - this changes from the standard exposure compensation guide (in the viewfinder) to the FEC one. Then half press the shutter, to activate the viewfinder display, then use the wheel on the back of the camera to change the reading.
Again, don't forget to manually cancel (zero) it when you've finished.
Have fun! :)
TeeJay
Joined Jun 2005
Feb 17, 2006 05:58 |  #15
ds06: it doesn't "physically" change the shutter speed, as that would have a knock-on effect to the overall exposure. It's tremendously usefull when using fill flash to "adjust" the amount of light from the flash reaching the subject - whilst leaving the shutter/aperture set for ambiant light.
2,092 views & 0 likes for this thread, 5 members have posted to it.
standard 20D flash
1190 guests, 122 members online
