If one has this ball head:
http://www.bhphotovideo.com …ofessional_ft_series.html![]()
What quick change system would you recommend? I would like to stick with an Acra style system.
Thanks.
Jul 14, 2014 18:22 | #1 If one has this ball head:
v35skyline Goldmember 3,572 posts Likes: 16 Joined Apr 2007 Location: San Diego, CA More info | Jul 14, 2014 21:34 | #2 Do you want a lever or screw clamp? X100s | X-Pro1 | X-T1 | XF 14 | XF 18 | XF 35 | XF 56 | XF 60 | XF 10-24
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Jul 14, 2014 22:40 | #3 Replace the whole head with a RRS BH-55 LR Jon
Jul 15, 2014 05:15 | #4 v35skyline wrote in post #17032305 Do you want a lever or screw clamp? I prefer the screw clamps.
Jul 15, 2014 05:19 | #5 Jon wrote in post #17032427 Replace the whole head with a RRS BH-55 LR Have you used the FLM ball head that I linked to?
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Jul 15, 2014 09:28 | #6 I have the Flashpoint equivalent; it's too small for your 150-500. Jon
Jul 15, 2014 16:18 | #7 I just realized I linked to the wrong ball head in my first post to this thread. I fixed the link.
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Jul 15, 2014 17:43 | #8 I'd take that 77 lb. capacity with a very large grain of salt. "Load capacity" is a very subjective measure. The RRS I linked to has a larger ball (more surface to "grip" when locking it down, thus a more solid hold) and isn't as high (less leverage available to introduce wiggles). It's also heavier, an indication of a more solid construction. Jon
Jul 15, 2014 17:52 | #9 Jon wrote in post #17034344 I'd take that 77 lb. capacity with a very large grain of salt. "Load capacity" is a very subjective measure. The RRS I linked to has a larger ball (more surface to "grip" when locking it down, thus a more solid hold) and isn't as high (less leverage available to introduce wiggles). It's also heavier, an indication of a more solid construction. Thank you very much for your opinion. I'll update this thread once I've got some "stick time" on the ball head. Hopefully I haven't made a mistake.
Jul 15, 2014 17:59 | #10 I'm thinking of going with this QC system.
Jul 16, 2014 18:42 | #11 The FLM-58 ballhead tested very well in dpreview's test: http://www.dpreview.com …ans-top-ball-heads-tested - John
Jul 17, 2014 08:17 | #12 sawsedge wrote in post #17036419 The FLM-58 ballhead tested very well in dpreview's test: http://www.dpreview.com …ans-top-ball-heads-tested So I'd expect the -48 to be quite excellent as well. If my Z1 wasn't already darn near perfect, I'd check out the FLM heads. The Markins clamp should be good too. Most well-known, well-liked brands are fine (better than fine) and it comes down to a matter of taste and what works for you. I tested a Markins Q20 which also has a 48mm ball and it was solid, held my 100-400 easily at any angle, so I expect the FLM will do fine with your 150-500. Let us know how it works in practice. That's encouraging. Thanks!
It's a month later and B&H still can't give me a shipping date for the FLM ball head so I cancelled the order. So now I'm looking at these three as possible choices.
gakoenig Senior Member 427 posts Joined Feb 2010 Location: Portland, OR More info | Aug 14, 2014 14:10 | #14 If Really Right Stuff is an option, Really Right Stuff is the answer... http://lu.ma
Russ61 Senior Member 265 posts Likes: 2 Joined Aug 2009 Location: Tacoma, WA area More info | Aug 14, 2014 16:45 | #15 The Arca Swiss Z-1 is an excellent option, but only if you order it thru Wimberley ($445
| Latest registered member is semonsters 1061 guests, 101 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
