I'm going to start doing weddings. Mostly for family at first but then for others. As most do I will be needing to have two bodies and lenses at hand most of the time especially since I will be working alone at first.
I have a 1Dx and 5D III with Grip that I typically connect with a Black Rapid strap (via the L-bracket with a 1" QR clamp) but often don't use both at the same time for most of the work I do. When I shoot sports one is typically on a monopod and the other on the sling strap.
For weddings I've thought about getting the dual black rapid strap but am concerned the bodies with large lenses (70-200mm f/2.8L II and 24-70mm f/2.8L II) will swing around and either hurt some one or worse yet get damaged when it hits something.
I know there are a lot of solutions out there but not sure which ones work well and are worth the investment. Probably will have a thinktank shooting belt and shoulder strap for it so I could attach to that with a Spider type solution. I know there is this Cotton carrier as well but don't know much if anything about it.
Would really like to get some advice from experienced wedding shooters to understand what works for you. Thanks in advance. Steve
