Thread started 19 Jul 2014 (Saturday) 18:14
Distortion
delta0014
Joined Oct 2013
Jul 19, 2014 18:14 |  #1
So from what I can tell, distortion is more of a problem when you stand close to something, not necessarily the focal length of the lens. Maybe I'm wrong?
Obviously the longer the focal length the further back you have to stand to get everything in the picture.
If so, are there any rules or guidelines for how far to stand away from something to avoid distortion? Like the 1/focal length, only for minimizing distortion. 5 feet, 10 feet, 15 feet or whatever distance.
Canon R6M2
RF Lenses L f2.8
Just a hobby - CC always welcome.
msowsun
"approx 8mm"
Gallery: 18 photos
Jul 19, 2014 18:28 |  #2
I would say 10' is about the minimum distance regardless of the focal length.
pwm2
"Sorry for being a noob"
Jul 19, 2014 18:31 |  #3
It isn't so simple.
It also depends on the field of view of the subject as you see it in real life, compared to the field of view as you see it in print.
If you see a human face life-size in print, you expect to see the same distortion as if a real person had stood at the same distance.
So if you use a wide-angle lens and goes much closer and take the shot then you wonder about the big nose in the print.
If you stand very close to someone, then you see a very large face and your brain knows that you are close. So the brain doesn't think it's strange that the nose is larger.
In the end, a crop of a photo from a wide lens will have the same amount of perspective distortion than a photo taken from the same distance with a longer lens. So if you stand two meters from someone and take one shot with a 10mm lens and one shot with a 200mm lens and you then crop the 10mm shot and print two faces of the same size, you end up with identical prints - except for the uncropped print from the 200mm lens having better quality.
SkipD
Joined Dec 2002
Jul 21, 2014 03:07 |  #4
delta0014 wrote in post #17042503 (external link)
There are no simple rules for perspective (relative sizes of objects at different distances from the eye or camera) control because the subject can vary a lot. For ordinary portraiture of a single person, keeping the camera six to ten feet from the subject will generally improve the perspective of the face. However, there are other issues when photographing buildings, and any distance rules for portraiture would not apply.
Skip Douglas
pwm2
Jul 21, 2014 07:53 |  #5
SkipD wrote in post #17045229 (external link)
There are even rules for how to aim the camera. Using a wider lens and pointing it straight ahead or pointing it a bit upwards (to get the top of high buildings) makes a big difference - as soon as the lens is aimed upwards, all the originally perfectly vertical lines will point inwards and the top of the buildings will look much smaller than the lower parts. And that's one of the reasons why this world got blessed with special tilt-shift lenses.
1,792 views & 0 likes for this thread, 4 members have posted to it.
Distortion
1505 guests, 133 members online
