I'm using a couple of these rt versions one on and one off camera. I have external power packs connected to both. One of these is a godox pb960. The other an unbranded nimh power pack. I have envelop AA batteries in each unit. I have the relevant custom function set to 1 meaning the units should be using the external power for the flashes and internal batteries for the transmitter etc.
My hope was that this would mean that the internal batteries would last all day with the external packs taking the strain. However this doesn't seem to be the case. I've notices that under heavy use... Eg outdoors in sun where were are probably using lots if full power flashes after about 30 mins the recharge of flashes becomes painfully slow. The external batteries still have lots of juice. Change the internal AA batteries and speed is restored.... Until later when we go through the process again. The external batteries are definitely being used - when the flash goes off they indicate the are proving power and testing indoors shows that On a full power flash charge times are definitely shorter than with them not connected.
It seems that the units may be ignoring the custom setting and using both internal and external to charge the flash?
Any ideas experience to help me? The point of investing in the external powered packs was to save the changing of the internal batteries and this hasn't happened. Also given that I have two different power packs with the same issue it seems to be a speedlite problem rather than some thing with the power packs.,,,
Help!
