Thread started 20 Jul 2014 (Sunday) 16:48
Some really stupid questions about heavier zoom lenses
The ­ Dark ­ Knight
Joined Apr 2012
Jul 20, 2014 16:48 |  #1
I'm considering the 70-200 f/2.8L (non-IS). It would be, by a decent margin, the biggest/heaviest lens I've owned. As such, I have some pretty dumb questions I'd like to ask...
(1) I've noticed these lenses come with a tripod collar. I've never actually used a tripod and I don't see a need to use one in my photography, so can this collar be removed?
(2) Does the existence of this collar mean that Canon suggests you should use a tripod whenever possible? What I mean by this is if I'm just using this lens for handheld shooting for several hours on a consistent basis, is the weight "bad" for the lens mount?
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jul 20, 2014 16:52 |  #2
Collar can be removed easily. It's only used when mounting to a tripod as the name implies.
When you DO use a tripod, you will always want to use a tripod collar with a lens of this size. The lens outweighs the body, and the balance will be WAY off if you try to mount to the body instead.
this does not in any way imply that you need to use a tripod. These lenses are used hand held FAR more often than tripod mounted. When you hold the combo, you will have one hand holding the lens. No additional wear or tear on the mount.
CDS' HOT LINKS
The ­ Dark ­ Knight
Joined Apr 2012
Jul 20, 2014 16:59 |  #3
CyberDyneSystems wrote in post #17044414 (external link)
Thank you, you concisely addressed all my questions!
Sorarse
Jul 20, 2014 17:21 |  #4
As CDS says, you only need the collar if you are going to mount on a tripod, as it reduces the strain on the lens mount. There is less weight on the mount when the lens is attached to the tripod compared to when the camera is attached to the tripod, simply because the lens weighs more than the camera.
At the beginning of time there was absolutely nothing. And then it exploded! Terry Pratchett
http://www.scarecrowim​ages.com (external link)
Canon PowerShot G2
DreDaze
Gallery: 49 photos
Jul 20, 2014 17:33 |  #5
sometimes you can use the tripod mount to carry the lens as well...so it kinda helps to take the strain off if you are handholding...at least for me.
Andre or Dre
gear list
Instagram (external link)
pwm2
"Sorry for being a noob"
Jul 20, 2014 17:34 |  #6
Sorarse wrote in post #17044465 (external link)
For a rather small and light lens as this actually is - compared to the really big whites - that collar isn't there because you need to reduce any strain on the lens mount. The mount is strong enough to handle this weight without need for any collar. Else you wouldn't be able to walk around with the camera just hanging in a strap.
The collar is there because if you fit the camera directly to the tripod head, then you have no weight behind the camera but you have the full lens weight infront of the camera. And that will make cheaper tripod heads sag. And any tripod head that hasn't a good setting for "reasonable friction" will be hard to use because whenever you try to adjust the direction of the camera you need to take up the full weight of the lens to properly aim the camera while tightening the tripod head again.
By instead using the tripod collar on the lens, you get a situation where most of the lens is infront of the tripod head. While a small part of the lens and the camera body is behind the tripod head. So there is balance. So when you try to adjust the aim of the camera, you don't have to fight any camera or lens weight.
Next thing - the tripod collar gives the advantage that you can rotate the collar around the lens. Which means you can rotate the camera between landscape and portrait while the collar is fitted to the tripod.
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Jul 20, 2014 17:34 |  #7
While the collar can be completely removed, my preferred method of use is to simply rotate the foot up above the lens barrel when hand-holding; then, should I want/need to throw it on a tripod, I can just rotate it down and do so.
pwm2
Jul 20, 2014 17:35 |  #8
DreDaze wrote in post #17044472 (external link)
Yes, it is a quite nice grip to lift the camera/lens combo in.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jul 20, 2014 17:51 |  #9
:) My lens collars are all on a shelf somewhere... prefitted with cheap ebay Arca lens plates,. but rarely used.
CDS' HOT LINKS
pwm2
Jul 20, 2014 17:54 |  #10
I like them too much to ever remove them.
And I like to hold the hand under the collar when hand-shooting.
Elton ­ Balch
Gallery: 11 photos
Jul 20, 2014 18:59 as a reply to  @ pwm2's post |  #11
The 70-200 F/2.8 non-IS weighs 50.6 ounces with hood and tripod collar per the digital picture's lens specifications page. The collar alone is 4.2 ounces so removing the collar is a tad more than an 8% weight savings. Here's a link to the lens specification page for even more information.
http://www.the-digital-picture.com …nsComp=0&Lens=2​42&Units=E (external link)
Elton Balch
5D Mark III, 7D Mark II, 24 mm f/1.4 L, 35 mm f/1.4 L, 50 mm f/1.2 L, 85 mm f/1.2 L, 100 mm f/2.8 macro, 135 mm f/2 L, 300 mm f/4 L, 16-35 f/4 L IS, 24-70 f/4 L IS, 24-105 f/4 L IS, 70-200 f/2.8 L IS II, 100-400 f/4.5-5.6 L IS ii, 580 EX Flash, Speedlight 600 EX RT, 1.4 extender, extension tubes and other stuff.
werds
"Yes, Sire. You'll shut your trap!"
Gallery: 12 photos
Joined Mar 2014
Jul 20, 2014 19:25 |  #12
pwm2 wrote in post #17044515 (external link)
This, due to my hand size/length, I find it MUCH more comfortable to shoot with the collar on facing down. I actually use it as a place to rest my palm leaving my fingers free to move the zoom and focus rings.
Again, might just be because of my hand size. The extra added weight of the collar long term is just not that big an issue to me, but I do recognize that it does add enough weight that when it is removed it is noticeable.
Gear: Nikon D750, Nikon D7200, Sigma 17-50 2.8 OS, Sigma 50-150 2.8 OS HSM EX , Nikon 70-200 2.8 VR1, Tamron 24-70 2.8 VC, Tamron 70-200 2.8 VC, Tamron 28-300mm Di VC PZD, Tamron 16-300mm VC PZD, Tamron 150-600 VC, Nikon AF-S 50mm 1.8, Nikon SB-900
POTN Seller Feedback (and other)
SuzyView
Jul 20, 2014 20:34 |  #13
I keep the one on my 70-200 2.8 IS II because it is heavy and I take my tripod with me most of the time I'm using it. Just make sure you keep track of all the stuff you don't use often. Otherwise, you'll end up like me, moving and not knowing where anything is. :(
Elton ­ Balch
Gallery: 11 photos
Jul 20, 2014 20:50 |  #14
SuzyView wrote in post #17044778 (external link)
Don't worry...whatever you misplace will show up just as soon as you buy a replacement! I have no plans to remove my tripod ring either; when you factor in a camera, battery pack and the 70-200 it's oversix pounds. Loosing four ounces won't make much difference.
Elton Balch
tempest68
Jul 20, 2014 20:58 |  #15
When I had the Sigma 70-200mm f2.8 I would attach the Black Rapid strap to the collar and not the camera body. If I wasn't using the strap, I would remove the collar.
Jim
Canon: EOS 3, 40mm f2.8 STM, 85mm f1.8 USM. Voigtlander: R3A, 28mm F2.8 SL II, Nokton 40mm f1.4, 50mm f2 Heliar.
Nikon: SB-25. Yongnuo: YN565EX, YN-622C transceiver (x2)
Sony: A7S, a6000, 24-240mm f3.5-6.3 G, Nissin i40.
3,783 views & 0 likes for this thread, 16 members have posted to it and it is followed by 2 members.
1461 guests, 131 members online
