Snafoo wrote in post #17046670
I'm not sure how your first comment is relevant, since vignetting is a function of the design and quality of a lens, not fundamental principles. As for your second comment, it makes no sense.
It is - kind of.
The full-frame sensor has a larger area. And this larger area will in total collect more photons. Since the number of photons collected at a given exposure level is a direct function of the sensor area.
So a full-frame sensor in the same technology as a smaller sensor will manage less noise. If the full-frame sensor has the same number of pixels as a smaller sensor, then each pixel will be larger and so collect a larger charge. So each individual pixel will have less noise.
If the full-frame sensor has the same size pixels as the small sensor, then each pixel will collect the same amount of light and will have the same amount of noise. But in this case the total sensor will have more pixels, so a full sensor print will have each individual pixel represent a smaller part of the print. So in this situation too, the full-frame sensor will give a print with less noise.
But as soon as the light level gets high enough, then even the small sensor will be able to collect enough photons that noise isn't really an issue. Which is a reason why mobile phones can manage excellent photos in good light.
Not really accurate.
Look at it this way - exposure is a function of the amount of light reflected off the subject. The camera can't create photons, it can only collect the ones coming from the subject. It doesn't matter how big or small the sensor is, or the size of the individual pixels, for that matter.
But it's still quite correct. The camera with the smaller sensor has a smaller lens that will pick up a smaller amount of photons reflected from the subject. But since it needs to distribute these photons over a smaller sensor, it will still manage to project the same photon density onto the sensor. So it manages the same exposure level. And same size pixels in a small and large sensor will each see the same number of photons.
