Thread started 21 Jul 2014 (Monday) 19:49
DOF button on cameral body
mikecox
Joined May 2011
Jul 21, 2014 19:49 |  #1
I can't figure out how this option works.
When I press the button the viewfinder screen darkens slightly but I don't see much of a change otherwise.
Michael :cool:
Canon 60D and 70D, Speedlite 430 EX II, PsCC, LrCC, and PrE 16
unistudent1962
Jul 21, 2014 19:54 |  #2
Hi Michael,
Pressing the DOF button closes the aperture of the lens down to whatever it is set at. This lets less light into the viewfinder, resulting in the darker view you are seeing. It also allows you to get an idea of the depth of field at the particular aperture you have set. DOF being the distance in front of and behind the object you have focussed on. The larger the f number, the greater the DOF, and the lower the amount of light entering the viewfinder and ultimately the sensor.
Canon 70D w/Grip l Canon 60D w/Grip l EF 100-400 F4.5-5.6L IS l EF 70-200 f4L IS l EF-S 15-85 f3.5-5.6 IS USM l EF 100mm f2.8 USM Macro l EF-S 18-55mm f/3.5-5.6 IS STM l EF 50 f1.8 II l EF-S 10-22 f3.5-4.5 USM l 430 EX II Flash l Manfrotto 055XPROB + 498RC2 Tripod l Benro MP-96 M8 Monopod l Lowepro Vertex 200 AW Backpack l Lowepro Pro Runner 300 AW Backpack l PS CS5 Extended l Lightroom 4.3
sandpiper
Jul 21, 2014 20:03 |  #3
mikecox wrote in post #17047030 (external link)
If it only darkened slightly, you probably weren't stopping down very far? That would mean that the effect isn't very obvious. If you set the camera to f/11 (or smaller if you are using a slow lens) then look at some detail that is soft in the viewfinder but not extremely close or far away, you should see it sharpen up as you stop the lens down with the DOF button.
It does take a little time to get the feel of using it, I used it for many years shooting film so it seems quite natural to me. Once you have played with it for a while you should start to get a feel for using it.
tonylong
...winded
Gallery: 60 photos
Jul 21, 2014 20:12 |  #4
I no longer have a camera with Live View, so I'm curious how the DOF button behaves if you're in Live View, and specifically if you are zoomed in so that you could see the details that would be soft wide open but would sharpen up with the DOF button pressed?
Using a viewfinder can be tricky unless you can clearly see the objects that are noticeably soft in the "normal" view!
I'm asking, but I haven't been a DOF button user myself!
Tony
WhyFi
Gallery: 246 photos
Location: I got a castle in Brooklyn, that's where I dwell.
Jul 21, 2014 20:20 |  #5
If you're focused at infinity, you may not see any differences in DoF, particularly with slow (aperture-wise) lenses and/or short focal lengths (wide angle views). With faster glass/at close focusing distances/longer focal lengths, it'll be more readily apparent.
Bill is my name - I'm the most wanted man on my island, except I'm not on my island, of course. More's the pity.
rrblint
Gallery: 84 photos
Joined May 2012
Jul 21, 2014 20:30 |  #6
tonylong wrote in post #17047100 (external link)
Live View is where the DOF preview really shines IMHO. If you have Exposure Simulation enabled then the LCD doesn't darken like the viewfinder does and you can really see the change in DOF.
Mark
oldvultureface
Gallery: 85 photos
Jul 21, 2014 20:33 |  #7
... so I'm curious how the DOF button behaves if you're in Live View, and specifically if you are zoomed in so that you could see the details that would be soft wide open but would sharpen up with the DOF button pressed?
Live view really shows how aperture changes affect DOF. Zooming in is even more telling.
LeeRatters
Jul 22, 2014 04:21 |  #8
I must say, I've never thought of using DOF Preview in LV. I very rarely use it anyway. I kinda forget that it's there!!
>> Flickr << (external link)
>> Instagram<< (external link)
WhyFi
Gallery: 246 photos
Jul 22, 2014 06:52 |  #9
LeeRatters wrote in post #17047722 (external link)
For tilt and/or macro/near macro, it's a very useful.
Bill ­ Emmett
Joined May 2012
Jul 22, 2014 10:55 |  #10
I would use it more, except it is in such a inconvenient location on both my 7D, and 6D. It needs to be closer to the shutter button, and more exposed or raised above the body contour. I find the DOF preview to be a valuable part of the camera.
New Canon EOS 5D Mark IV, Canon EOS 7D Mark II, Canon EOS 50D, Canon 7D Classic, Canon 6D, Canon EF 70-200 f4L USM with IS, Canon 40mm pancake, Canon EF 50mm 1.8, Canon EF-S 10-22mm wide angle, Canon EF-S 18-135 IS STM, Canon EF 100mm 2.8L USM Macro, Tamron 18-270mm Dii VC, Tamron SP 150-600mm VC, Tamron SP 24-70mm f2.8 VC USM, Canon EF 16-35 f2.8L II USM, Tamron 2X Tele-Extender, 1.4 Tele-extender
teekay
Joined Apr 2001
Jul 22, 2014 11:12 as a reply to  @ Bill Emmett's post |  #11
Tried it a few times on my 60D but IMHO it's the most useless and and inconveniently placed feature on the camera.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jul 22, 2014 11:56 |  #12
I use it all the time, it's easy to hit with my pinky on a 1D,.
CDS' HOT LINKS
JohnPh
I smell like a Shoulder Shrugging Seal
Gallery: 205 photos
Joined Oct 2011
Jul 22, 2014 12:11 as a reply to  @ CyberDyneSystems's post |  #13
Yep I use dof preview in live view all the time for my landscape stuff, really helps!
ՕFlickr (external link)
Facebook (external link)
serial underexposer
Gear
tonylong
...winded
Gallery: 60 photos
Jul 22, 2014 12:50 |  #14
We haven't heard back yet from Michael (the OP) --
I'm curious as to whether you want to experiment with this stuff? Using the button viewing through the viewfinder, then trying it out with Live View?
Tony
AJSJones
Gallery: 6 photos
Joined Dec 2001
Jul 22, 2014 13:58 |  #15
WhyFi wrote in post #17047867 (external link)
This:D
I'd go even further and say it's essential (LV, exp sim, 10x DoF preview) if you want to get the most out of the tilt functions in a TS lens. For landscapes without a TS lens, you can check near and far focus points in the image that will be acquired (not the ones in some DoF table:D) and only stop down as much as is absolutely needed - can help minimize diffraction losses if deep DoF is needed.
My picture galleries (external link)
3,308 views & 0 likes for this thread, 20 members have posted to it and it is followed by 2 members.
1316 guests, 160 members online
