travisvwright wrote in post #17053495
To test the cable connect it to your flash. Bend a paper clip and touch the tip and the sleeve at the same time. The flash should fire.
No need to waste a valuable resource like a paperclip
, simply stick the tip of a ballpoint into the end of the plug when the cable is connected to the flash PC port. If it fires, it's good. If not, trash immediately (....the cable. Trashing the pen is optional)
If you want to start getting all techie, a multi-meter set to resistance (Ω symbol) will check it. Set to the lowest range, connect one probe to the outer sleeve of a plug at one end and the other to the plug outer sleeve at the other end. Theory has it that the resistance should be Zero but it never quite is. As long as it's really low, that's OK (figures are pretty much irrelevant but I'd be happy with 2 to 3 Ω). Now do the same but connecting ONLY to the centre pin in each plug - careful you don't touch the outer sleeve as well. Again, you're looking for a low, low reading. You do need BOTH these readings to be as near zero as possible. Then you know you have a good lead. For the time being
Ideally you should regard sync leads as a consumable just like an ordinary AA battery. Most commercial leads use wire about the thickness of baby hair and this breaks astoundingly easily. I used to make my own with microphone cable (much tougher) but can't get the solder-on plugs any more.
