Thread started 16 Feb 2006 (Thursday) 21:56
Settings question for PSCS2
Sam
Feb 16, 2006 21:56 |  #1
Hello,
I hope someone can understand my issue. I can't give an example so I hope my explaination is enough.
When I am viewing images in the main photoshop window they are very pixelated almost to the point of looking cartoonish. Not the entire image, mainly in the shadows ar any area that is thrown out of focus due to a shallow DoF.
When I view the image in microsoft picture and fax viewer or an internet browser ( I used IE explorer as well as firefox) The image looks fine.
I am guessing that I unknowingly changed a setting somewhere and I have no idea what it could be. Has anyone seen anything like this or know what I am talking about?'
Thank you in advance for any help!
Sam
RAitch
Feb 16, 2006 22:01 |  #2
If you go into the preferences dialog, I think you can hold down ALT to change the cancel button to RESET. Should reset your options to default I'd imagine.
Perhaps it's your colour space. Edit > Colour Settings
Maybe it's something to do with AdobeRGB?? Same thing, hold ALT and click Reset.
See Through The Lens (external link)
Sam
Feb 16, 2006 22:09 as a reply to  @ RAitch's post |  #3
Thank you RAitch, I tried that but it is the same. I started noticing the problem last night but I thought it was the images themselves. So tonight when I say it again I viewed the images on other programs without issue.
I have a feeling this is going to drive me insane tonight.
RAitch
Feb 16, 2006 22:12 |  #4
Would an ALT-PrtSc of the PS window and the other application side by side show the difference?
Maybe that will give us an understanding of the problem so we can see the difference in your images.
Could it be something with the Adobe Gamma thing (calibration for Adobe that other apps don't use)?
Sam
Feb 16, 2006 22:23 as a reply to  @ RAitch's post |  #5
Ok, I just fixed it, but I don't ever remember having to adjust This setting in the years that I have used photoshop.
Under the "View" menu if I check "Proof Colors" and then select "Monitor RGB" from the "Proof Setup" dropdown menu it solves the problem. I never set this before? Is it normally this way by default?
Thank you very much for trying to help.
Hopefully if anyone else ever has this problem they find this thread...
RAitch
Feb 16, 2006 22:26 |  #6
After opening a new image, my Proof colour option is not selected. Under the Proof Setup menu, I have "Working CMYK" selected as my option.
Weird...
Sam
Feb 16, 2006 22:31 as a reply to  @ RAitch's post |  #7
I have to select it each time I open a new image.... Odd.
DavidW
Feb 16, 2006 22:42 |  #8
The problem could be a bad monitor profile - the applications you mention as not having a problem with aren't colour managed.
David
Sam
Feb 16, 2006 23:43 as a reply to  @ DavidW's post |  #9
David
How would I fix that if it were the problem?
[EDIT] I am only having the issue in photoshop.
RAitch
Feb 17, 2006 07:18 |  #10
Thanks for backing up what I thought in post 4 David.
Sam, did you ever run through Adobe Gamma? Play around with that, maybe you can deactivate it or erase the current profile or something.
I can't help out more if that's the cause. I don't use Adobe Gamma at all.
1,136 views & 0 likes for this thread, 3 members have posted to it.
2431 guests, 107 members online
