genesimmons wrote in post #17059928
thank you so much for taking the time to fully explain the split,i totally get it now
You're welcome.
forgive me if i sound stupid does metering bounce off the mirror,does metering come after the focus screen,so the light comes thru the lens bounce off the mirror thru the focus screen into the camera,sorry if that doesn't make sense but I'm not sure how metering works,again thanx for the great explanation
Katzeye is the brand with which I most familiar. From their website:
Metering Information
The KatzEye™ focusing screen for the Canon 40D/50D/60D has little to no effect on light metering in Evaluative or Center Weighted metering modes. Partial and Spot metering modes are somewhat more affected, depending on conditions. We recommend use of the Ef-A selection in the camera’s focusing screen type custom function for most accurate results. Please see your owner’s manual for instructions on adjusting the custom function settings. Detailed test results for each of the four metering modes are as follows*:
Evaluative Metering Mode: Our testing showed evaluative mode to be within factory tolerance for all lenses having a maximum aperture of f4.5 or larger (lower f number). AF lenses with a maximum aperture of f5.6 or slower (higher f number) will overexpose slightly. With an f5.6 AF lens, we recommend an exposure compensation of -2/3EV. Manual (non-CPU) lenses with a maximum aperture of f5.6 or slower (higher f number) will underexpose slightly. With an f5.6 non-CPU lens, we recommend an exposure compensation of +2/3EV.
Center Weighted Average (CWA) Metering Mode: Our testing showed CWA metering mode to be within factory tolerance for all lenses having a maximum aperture of f4.5 or larger (lower f number). Lenses with a maximum aperture of f5.6 or slower (higher f number) will underexpose very slightly. With an f5.6 lens, we recommend an exposure compensation of +1/3EV.
Partial Metering Mode: Our testing showed partial metering mode to be within factory tolerance for all lenses having a maximum aperture of f2.0 or larger (lower f number). Lenses having a maximum aperture smaller than f2.0 (lager f number) will show a shift toward increased exposure. The shift will be greater for lenses with smaller maximum apertures. When using partial metering mode, it is advisable to first take a test shot, check the histogram, and adjust exposure compensation as required. Starting points for exposure compensation are as follows: f2.8 lens: -1/3EV, f4.0 lens: -2/3EV, f5.6 lens: -1EV.
Spot Metering Mode: Our testing showed spot metering mode to be within factory tolerance for all lenses having a maximum aperture of f2.0 or larger (lower f number). Lenses having a maximum aperture smaller than f2.0 (lager f number) will show a significant shift toward increased exposure, with the shift increasing for lenses with smaller maximum apertures. Spot metering mode is not recommended when using a split prism focusing screen except with very fast prime lenses. However, if spot mode must be used, it is strongly advised to first take a test shot, check the histogram, and adjust exposure compensation as required.
* Note: Metering test results presented are based on testing of the 40D model. While results are expected to be similar for the 50D and 60D, users of these models are strongly encouraged to take a test shot and check the histogram before beginning any critical shooting.
Katzeye LINK
This focus screen is more than $25 so the one you choose for that dollar amount may not perform as well.
If I remember correctly, the exposure sensors are above the focus screen somewhere (??) in the pentaprism housing. So the light has to pass through the focus screen first. I'm sure some optical physicist will chime in here to correct me soon.
Dwain
