Thread started 27 Jul 2014 (Sunday) 10:25
Help..
davidmtml
Joined Jun 2012
Jul 27, 2014 10:25 |  #1
I was out last night taking a couple shots with my new barn-door tracker, and was using my RF-603's as a shutter trigger, since I forgot my intervalometer at home. When I was taking the cable out of the shutter remote port, the end of it broke off in my camera (5Dc)! I tried to pull it out with a pair of needle-nose pliers, but it doesn't seem to want to come out. I'm scared to pull too hard, I don't want it to break further down in. Any way I can make this easier??
IMAGE: https://farm4.staticflickr.com/3912/14571456387_424a48cb03_b.jpg
IMAGE LINK: https://flic.kr/p/ocCw​jF  (external link) 20140727-085315-IMG_3888 (external link) by David Rabenberg Photography (external link), on Flickr
IMAGE: https://farm3.staticflickr.com/2929/14571209410_442e5a33f6_b.jpg
IMAGE LINK: https://flic.kr/p/ocBf​Us  (external link) 20140727-085306-IMG_3887 (external link) by David Rabenberg Photography (external link), on Flickr
IMAGE: https://farm4.staticflickr.com/3891/14777779573_3aed5e454e_b.jpg
IMAGE LINK: https://flic.kr/p/ovRZ​1Z  (external link) 20140727-085233-IMG_3885 (external link) by David Rabenberg Photography (external link), on Flickr
tongard
Gallery: 6 photos
Jul 27, 2014 11:16 |  #2
if it was me I would use a pair of waterpump pliers and give it a tug, its only straight pin connector inside cant see u will do any harm
Canon 6d, 7d2.
Canon 50 1.4, 28mm 2.8 is , 24-85, 24-105, 70-200 f4 is
Sigma 150-600
davesrose
Title Fairy still hasn't visited me!
Jul 27, 2014 11:19 |  #3
If it won't budge with pliers or tweezers, I don't think you can do much except take it to a repair shop. They may have to take the camera apart to get to the whole connection. It does look troublesome, since there appears to be a gap in the center (shouldn't fuss too much less you bend the pins). Maybe if you have a pair of those small curved scissors or and x-acto blade, you can try prying it out from the center....I know it's tempting to keep on fussing to get it out. But there's then increased odds you'll break the pins!
Canon 5D mk IV
EF 135mm 2.0L, EF 70-200mm 2.8L IS II, EF 24-70 2.8L II, EF 50mm 1.4, EF 100mm 2.8L Macro, EF 16-35mm 4L IS, Sigma 150-600mm C, 580EX, 600EX-RT, MeFoto Globetrotter tripod, grips, Black Rapid RS-7, CAMS plate and strap system, Lowepro Flipside 500 AW, and a few other things...
smugmug (external link)
Jim_T
Joined Nov 2003
Jul 27, 2014 12:00 |  #4
Like tongard says... The remote just press-fits into the socket so it should slide out with little problem. It looks like there's enough plastic protruding to grab with a pair of pliers.
I don't think they have to be water pump pliers specifically.. Any type that will afford you a firm grip should do.
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Jul 27, 2014 13:17 |  #5
I had exactly the same thing happen a few weeks ago with my 603 cable. I used pliers and was able to pull it out without a problem.
Dan Marchant
davidmtml
Joined Jun 2012
Jul 27, 2014 13:32 |  #6
Dan Marchant wrote in post #17059441 (external link)
Thanks everybody, I was able to get it out with pliers. Broke a few pieces off, but managed to get it out!
I tried my other 603 cable, and it is a super tight fit as well...they must've just made them a hair too big.
Conradebner
Gallery: 232 photos
Joined Jun 2012
Jul 27, 2014 14:49 |  #7
Tweezers?
1DX, R5, 400 2.8 V2, 300 2.8L, 70-200 2.8L IS II, 24-70 2.8L, 300 2.8L IS, 200 2.8L, 7D, 40D, 100 2.8 Macro, 580EX II
Www.IE3photo.com (external link)
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Jul 27, 2014 19:26 |  #8
davidmtml wrote in post #17059468 (external link)
Yep I noticed the same thing.
Dan Marchant
1,382 views & 0 likes for this thread, 6 members have posted to it.
Help..
1497 guests, 137 members online
