Thread started 28 Jul 2014 (Monday) 07:33
Canon 70-200 f4 with Canon Extender EF 1.4X III ???
guntoter
Jul 28, 2014 07:33 |  #1
I have a friend who is using the 75-300 lens, and he is realizing it isn't that great. He told me it is soft at 300mm.
He ask me about the 70-200 f4. I told him that everything I hear about this lens is that it has stellar pictures from end to end. Also, it is priced very good for an L lens.
Then he wanted to know if you can use the Canon 1.4 extender with it. Is it usable? Does it auto-focus? I told him I don't know, but I thought I would throw it out here for feedback.
Joel
GEAR
jimewall
Jul 28, 2014 08:46 |  #2
It will AF with a 1.4X. (No AF with a 2X, except 1D series and 3DIII with the correct firmware.)
Thanks for Reading & Good Luck - Jim
GEAR
guntoter
Jul 28, 2014 08:59 |  #3
jimewall wrote in post #17061138 (external link)
Thanks jimewall,
Do you know what the f-stop will be pushed to for this combo?
Joel
GEAR
yourlefthand
Joined Mar 2012
Jul 28, 2014 09:12 |  #4
guntoter wrote in post #17061168 (external link)
Thanks jimewall,
4 * 1.4 = 5.6
40D, Tamron 17-50, 50mm 1.8 Mk I, 55-250 IS, Sony Nex-7, Fuji X10
jimewall
Jul 28, 2014 09:16 as a reply to  @ guntoter's post |  #5
Easier to just think of a 1.4X giving an additional stop, so f/5.6 (rather than using the calculation given above by yourlefthand)(FWIW a 2X is 2 stops). A maximum of f/5.6 is where Canon causes unaltered lenses to disable AF (except 1D series and 3DIII with the correct firmware).
Keep in mind a f/4-5.6 lens with a 1.4X still AF, because the lens still has f/5.6 as the max aperture (f/5.6-8).
GEAR
guntoter
Jul 28, 2014 09:34 |  #6
Thanks guys for the info.
Joel
GEAR
crofter
Joined Aug 2011
Jul 28, 2014 09:47 |  #7
It will however AF in live view with a 2x.
http://www.flickr.com/​photos/70718847@N02/ (external link)
jimewall
Jul 28, 2014 10:29 |  #8
crofter wrote in post #17061261 (external link)
In what kind of light?
How is AF Accuracy?
How much loss of AF speed?
IQ quality?
I prefer using the right lens, but have tried with only my long zoom, but you can also tape the pins on some TCs and it keeps AF - Sort of! The above stink for most lenses, and there has to be excellent light (and contrast). My guess (haven't tried) the same is for LV.
GEAR
ldn323
Gallery: 463 photos
Jul 28, 2014 17:38 as a reply to  @ jimewall's post |  #9
Here is an example of 70-200mm f/4 IS + 1.4x II on a 7D (full AF, of course):
IMAGE: https://farm6.staticflickr.com/5577/14493858275_375c933ba2_b.jpg
IMAGE LINK: https://flic.kr/p/o5LP​7c  (external link) IMG_0831 (external link) by ldn323 (external link), on Flickr
(The original picture looks much sharper than this. I do not know what on Flickr that causes this IQ degradation)
Hope this helps.
guntoter
Jul 28, 2014 20:31 |  #10
ldn323 wrote in post #17062340 (external link)
Hope this helps.
I will have to show my friend this pic. Great job.
Joel
GEAR
herculeorama
Gallery: 62 photos
Joined Sep 2012
Jul 28, 2014 23:38 |  #11
This one with 70-200 f/4 IS with Canon 1.4x III TC
IMAGE: https://farm4.staticflickr.com/3886/14587281607_1ccda03138_b.jpg
IMAGE LINK: https://flic.kr/p/oe2C​Bi  (external link) Velavadar_4452 copy (external link) by jhsurti (external link), on Flickr
5D Mark III | Sigma 24/1.4 A | 50/1.8 | 100/2.8 Macro | 17-40/4 L | 24-105mm f/4 L IS USM | 70-200/2.8 L IS II USM | 400/5.6 L | Canon 1.4x III TC| Canon 2x III TC
jhsurti
guntoter
Jul 29, 2014 09:37 |  #12
herculeorama wrote in post #17062988 (external link)
That is impressive.
Joel
GEAR
JWdlft
Joined Feb 2013
Jul 29, 2014 13:21 |  #13
jimewall wrote in post #17061198 (external link)
No. First of all the Canon 1.4× extenders III are not compatible with any 4-5.6 lenses. You'll find a compatibility chart here at B&H (external link).
Second, on variable aperture lenses the aperture at any given focal length counts, not the aperture at widest focal length. So a 1.4× might work at shortest focal length at f/4 (=5.6 with 1.4× extender) but it goes over 5.6 fast on zooming in.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jul 29, 2014 13:27 |  #14
This (all 70-200mm zooms actually) is one of the few zoom lenses that will really work quite well with a 1.4x t-con!
CDS' HOT LINKS
jimewall
Jul 29, 2014 16:04 |  #15
JWdlft wrote in post #17064185 (external link)
CyberDyneSystems wrote in post #17064200 (external link)
Agreed for Canon TCs (all not just MKIIIs), but you can use a Canon TC on pretty much any lens if you add a extension tube (yes you lose infinity focus). Also Canons Life Size Converter fits all Canon but EF-S lenses (It is bassically a TC-ET combination with no front protrusion like other Canon TCs).
But my posts were generic, only the OP and you two (in these two posts) mentioned the Canon TC. I just answered the OP's question based on 1.4X and 2X TCs. Off brands TC do fit all EF (not EF-S) lenses, those were what I was basing my statements against).
Keep in mind the Sigma 150-500mm f/5-6.3 DG OS and Tamron 150-600mm f/5-6.3 VC focus through there entire range, and the high end is over 5.6. I suppose the lens may trick the camera, but they report correctly.
I assumed (not always good) that the ability to AF was based off of the lowest aperture on the lens. The reason for my assumption is anytime I've tried a TC on those kind of lenses, if the wide end auto-focuses then the tele end (even if beyond f/5.6) also still auto-focuses. Note: I've only tried it with the Sigma 10-20mm f/4-5.6 and the Canon 70-210mm f/3.5-4.5 - but they auto-focus through the entire range. Again it is a guess/assumption, but I don't truly know.
GEAR
8,273 views & 0 likes for this thread, 10 members have posted to it.
1054 guests, 103 members online
