Thread started 17 Feb 2006 (Friday) 03:09
white balance settings when using flash and other lighting?
mrklaw
Feb 17, 2006 03:09 |  #1
Hi
I have a canon 350d and I'm curious what WB settings to use when I'm using flash along with available light. Do I use the flash WB - what happens to the background being exposed with available lighting?
Mostly I'll be doing this indoors where I have halogen lights, but it'd be good to know about outdoors too.
flash may be onboard or I have a 430EX too, if there is any difference in approach between the two.
thanks!
no dear, it didn't cost much at all
my stuff
tim
Light Bringer
Feb 17, 2006 03:36 |  #2
I use AWB 99% of the time. Your light colors will be different, you can fix that in RAW by doing a blended exposure in photoshop, or you can gel your flash to match the ambient. Gel is easier if you have gels, photoshop means less work when shooting but a bunch more later.
René ­ Damkot
Feb 17, 2006 11:18 |  #3
Another option is just to set the WB to the availiable light source's WB, and match the flash by using a filter. That's the reason a 'daylight to tungsten' correction filter is living on my flash all the time ;)
edit: Note to self: Read Tim's post more carefull next time. :o
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
jrsforums
Feb 17, 2006 12:38 as a reply to  @ René Damkot's post |  #4
There was a discussion sometime ago of matching tungsten lighting: https://photography-on-the.net/forum/showthre​ad.php?t=82389 See my post #6
John
John
1,151 views & 0 likes for this thread, 4 members have posted to it.
1190 guests, 122 members online
