Thread started 17 Feb 2006 (Friday) 04:25
Photoshop - Need Help! Easy question.
holly1230_11
Joined Jan 2005
Feb 17, 2006 04:25 |  #1
I don't know why i'm having so much trouble with such an easy thing...:oops: How do i move pictures onto a blank page to make a collage? Doesn't even have to be fancy. Thanks for any help.
nitsch
Feb 17, 2006 04:37 |  #2
Hi Holly, easiest way is to use the Move tool (little cross with an arrow icon) - hit V to select it. You can then click on your images and drag them over to your white background. The cool thing is that each image will be put on a new layer so you'll be able to position and modify them easily. Hope this makes sense. Have fun! :D
holly1230_11
Joined Jan 2005
Feb 17, 2006 04:54 |  #3
Thanks Nick. I'm able to move the image but now how do i make each image smaller so more than one will fit?
nitsch
Feb 17, 2006 05:55 as a reply to  @ holly1230_11's post |  #4
Select the layer which contains the image you want to resize then click on Edit, Transform then Scale and drag the edges/corners of the box in to resize then hit enter. To keep the proportions of your image intact hold SHIFT whilst dragging.
EOS_JD
Feb 17, 2006 07:06 as a reply to  @ nitsch's post |  #5
If you make sure rulers are shown, you can click on the ruler and drag down/across and you will be able to drop guides on your image so that you can keep your images aligned if needs be.
cheers
Jim
All My Gear
5D MkIII & 5D MKII + Grips | 24-70 f2.8L IS | 24-105 f4L IS | 70-200 f2.8L IS MkII | 50 f/1.4 | 85 f1.8 | 100 f2.8 | 1.4x MkII | Tamron 17-35 f2.8-4
holly1230_11
Joined Jan 2005
Feb 17, 2006 07:27 |  #6
Thanks a bunch to you both. Problem solved & I've learned something new already today :).
1,136 views & 0 likes for this thread, 3 members have posted to it.
2431 guests, 107 members online
