i have a canon mv730i camcorder. i can only transfer video's from the sd card and not the cassette wat do i need to transfer the video to the pc so i can write it on a cd.
kapurakshay Hatchling 6 posts Joined Feb 2006 More info | Feb 17, 2006 04:33 | #1 i have a canon mv730i camcorder. i can only transfer video's from the sd card and not the cassette wat do i need to transfer the video to the pc so i can write it on a cd.
CaptainHaddock Hatchling 5 posts Joined Feb 2006 Location: Dublin, Ireland More info | Feb 17, 2006 18:54 | #2 well you'd need the USB or firewire cable that came with your camcorder for a start... just plug it into the right port... as soon as your pc recognises the device, either use the software supplied with the camcorder to automatically transfer the video or open the folders of the device and copy and paste the video file to your hard disk(you'll recognise it easily, its an mpeg file usually)... i'm assuming you know how to write the video onto a cd once you've transferred the video to your pc... hope that helps... cheers DSLR N00b ...
| Latest registered member is IoDaLi Photography 1474 guests, 147 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
