I want to dive into the IR photography world. I have the 7D and 5D Mark III. My 7D rarely gets used since buying my 5D Mark III. I was toying with having the 7D converted, but the extra reach with the crop factor and 2 frames per second faster burst still have more advantage for wildlife vs the 5D Mark III. Depending on what Canon does with the rumored 7D replacement may make my decision for me on whether to convert my 7D or not. In the mean time, what about converting an EOS-M?
After watching several reviews on the EOS-M, it sounds like it is a pretty solid performer with some exceptions. The big issue seems to be AF speed. If I am using an EOS-M dedicated to IR photography only, I do not see AF speed as an issue. After all, I have never in my life needed to run around tracking a moving tree or other foliage worrying about fast AF before it can get away from me. I think shooting a majority of stationary objects in IR should give me the luxury of time to wait for the focus to dial in without missing the shot.
If you wanted to have a body converted to IR and didn't want to convert any of your existing bodies, would the EOS-M be a decent route to go? I can still use my existing lenses with the adapter. It won't take up much space in the camera bag. You can get a brand new EOS-M body for $300 or less now that it is discontinued. The body, lens adapter, and IR conversation service still comes in at less than buying an entry level DSLR. This thing will pretty much be a one trick pony after the conversion is done which is the main reason I am hesitant to convert my 7D. Am I going in the right direction or would you recommend something else?
