I was lucky enough to find this wonderfully preserved dragonfly exuvia. I did the obligatory field-shots and then took the exuvia home to do some studio shots where I wanted to experiment with magnification and lighting. The first shot is a natural light which I used as my starting point. I rather like the dramatic lighting and the way the light falls on the top-half of the exuvia helping to give a three-dimensional look.
After the natural light shot I decided to try and bring out a bit more clarity and definition and so experimented with two diffused flashes. After having taken some flash only shots I thought that although they substantially increased sharpness they looked too flat for my licking. A third alternative was to simply augment natural light with flash and this produced an acceptable compromise.
MPE 65mm macro at just over 1x with two diffused flashes. With hindsight I can see that I should have diffused the main flash a tad more.
The diffusion appears better at 2x on the MPE than on the 100mm macro. This is probably due to the flash heads and lens being closer to the subject.
Last shot is at 2x
