Has anyone had this problem?
When I use my Yonguno flash triggers on my 7D they are fine but put them on my 1Dmkiv and they won't work. If the flash is put on the mkiv it works fine.
ICee Senior Member More info | Aug 04, 2014 14:57 | #1 Has anyone had this problem?
110yd Senior Member 790 posts Likes: 35 Joined Jan 2005 More info | Aug 04, 2014 17:09 | #2 ICee wrote in post #17075952 Has anyone had this problem? When I use my Yonguno flash triggers on my 7D they are fine but put them on my 1Dmkiv and they won't work. If the flash is put on the mkiv it works fine. What YN triggers are you using?????
Thorrulz Goldmember More info | Aug 04, 2014 17:59 | #3 I think there are compatibility issues moreso with the YN products when pairing with Canons pro bodies. When I owned a 1ds miii one of my more expensive YN flashes would cause a color cast when shooting at 1/250th or 1/160th. Only on that body though and not on the 5D or t2i that I owned. It seemed like one of the YN triggers didn't work either on my 1d series bodies either before I switched over to the Cactus V5 triggers. Flickr
Aug 05, 2014 07:38 | #4 622 and even a 10 yards there not talking
Aug 05, 2014 07:39 | #5 Thorrulz wrote in post #17076306 I think there are compatibility issues moreso with the YN products when pairing with Canons pro bodies. When I owned a 1ds miii one of my more expensive YN flashes would cause a color cast when shooting at 1/250th or 1/160th. Only on that body though and not on the 5D or t2i that I owned. It seemed like one of the YN triggers didn't work either on my 1d series bodies either before I switched over to the Cactus V5 triggers. I'm wondering if it something like that but they work on my old 1dmkii
| Latest registered member is semonsters 1024 guests, 108 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
