Thread started 17 Feb 2006 (Friday) 12:33
Photoshot technique needed...
Radtech1
Everlasting Gobstopper
Joined Jun 2003
Feb 17, 2006 12:33 |  #1
I am trying to discover a way to "select" only the darks, or only the lights on a given shot. Ideally, it would not needed to be done with the eyedropper as in "Color Range", as I am hoping to put it into an action. Is there a way to, say, "Select Values" and input "0 to 100" or "155 to 255".
Would Lab Mode, or Alpha Channel be a way to accomplish that?
And if I can be completely greedy on it, have the selection be graduated, so that "0" is 100% opaque and "100" is only 1% opaque.
Thanks,
Rad
Be humble, for you are made of the earth. Be noble, for you are made of the stars.
DavidW
Feb 17, 2006 14:37 |  #2
I've not yet got to creating my own actions, but in Photoshop CS2 on Windows, I can use
CTRL + ALT + ~ to select by luminosity.
Save Selection As Channel on the Channels pane.
CTRL and D to deselect.
Select the Alpha Channel.
Apply a curve that is on the bottom until you reach the desired value - then on the top.
Optionally reselect RGB and load the Alpha Channel as the selection.
That does everything you want, except being an action.
David
996 views & 0 likes for this thread, 2 members have posted to it.
2420 guests, 106 members online
