Thread started 05 Aug 2014 (Tuesday) 15:23
Edit in PS from LR
Gaarryy
Aug 05, 2014 15:23 |  #1
Greetings
It used to be when I would edit a photo in PS from LR. Once I would do the basic save ( not save as), that image would automatically save back into LR right next to the original version. Now when I'm doing it, the photo will be saved to the very end of that particular import. it's quite a pain the then, go back up to where that photo was, to continue in order.
Since I'm guessing that setting was changed in that last update, I can't remember how to set it back up like that.
any help?
---------------Camera, Lens, Flash stuff.. but still wanting more
BigAl007
Gallery: 556 photos
Aug 05, 2014 16:29 |  #2
You have probably set the sort order to last imported/created instead of exposure as the sort order. I think there may be a short cut key to change the sort order as it happens to me at times. I'm on 4.4.
Alan
Mrjeans
Aug 05, 2014 23:46 |  #3
1) in LR go to 'library'
2) Menu - > View - > Sort -> order by capture time
3) Enjoy Post Processing without hassle
Canon 5D MK iii &7D,
85 f/1.2L Mkii,
50 f/1.2L,
35mm 1.4 DG HSM,
70-200 L f/2.8 IS
Levina ­ de ­ Ruijter
I'm a bloody goody two-shoes!
Gallery: 457 photos
Best ofs: 12
Aug 05, 2014 23:56 |  #4
Also, the "Previous Import" folder has "added order" as the default order and with every new import will revert back to that default, so make sure you're always working from the proper folder!
Wild Birds of Europe: https://photography-on-the.net …showthread.php?​p=19371752
Please QUOTE the comment to which you are responding!
Gaarryy
Aug 06, 2014 15:09 |  #5
Thanks all.
919 views & 0 likes for this thread, 4 members have posted to it.
Edit in PS from LR
1452 guests, 137 members online
