Thread started 05 Aug 2014 (Tuesday) 16:30
Focus on distant objects comes out soft
davidfarina
Gallery: 43 photos
Joined May 2013
Aug 05, 2014 16:30 |  #1
This is something ive noticed a few times. Im taking my 50L, something like f/2 focus on a subject 10 meters away. The image comes out soft even thought i micro adjusted it. It focusses properly at distances like 2-5 meters but everything more distant comes out soft. Its not even that i can see a part on the image which is in focus, its absolutely everything soft. Then again its the 50L so its a bit a special case. But why dies this happen also with my 70-300? Exactly the same, tack sharp wide open and at normal distances, but everything after 20 meters comes out not as sharp as id wish.
Any advices?
Sony A7RII | Sony A7S
EF 40 | EF 70-300L | FD 35 Tilt-Shift
FE 16-35 | FE 28 | FE 90
CV 15 4.5 III | CV 40 1.4 MC | Summilux 50 ASPH
Website (external link) | 500px (external link)
BrickR
Joined Mar 2011
Aug 05, 2014 16:32 |  #2
Shutter speed too slow?
My junk
The grass isn't greener on the other side, it's green where you water it.
davidfarina
Gallery: 43 photos
Joined May 2013
Aug 05, 2014 16:40 |  #3
BrickR wrote in post #17078295 (external link)
Definitely not. Was shooting the 50L at 1/4000s because it was sunny (hebce stopped down to f/2). The 70-300 was shot at 1/800s and it also has IS.
What do you think, could it be because my hands are so steady that the IS is counter-productive?
speedync
Gallery: 291 photos
Joined May 2011
Aug 05, 2014 16:52 |  #4
Which camera? Or are they both doing it?
davidfarina
Gallery: 43 photos
Joined May 2013
Aug 05, 2014 16:57 |  #5
speedync wrote in post #17078341 (external link)
I am such an idiot. As you say i just realized ive used the 70-300 on my 650D. Well the rebel has no MFA so most likely its a bad combination of camera lens. Ill try it again with my 6D.
But hows it possible for the 50L on my 6D not to produce good results. I mean i cant find a sharp spot on the image.
speedync
Gallery: 291 photos
Joined May 2011
Aug 05, 2014 17:07 |  #6
davidfarina wrote in post #17078354 (external link)
Well, I see it like this. It, the camera, is not 100% accurate 100% of the time in AF'ing. When you start shooting at f/1.2- f/2, the plane of focus is very thin, and the cameras AF sensor can mess up at times. It will sometimes lock onto something way different than what you placed the focus point over. Usually something with far better edge contrast than where you placed the AF point. I've noticed on my own camera, that point is sometimes nowhere near the selected point. Like diagonally opposite where the selected point is. As, you've noticed, sometimes it just plain gives up. If it does it all the time, or with alarming regularity, something is not quite right, out of spec, or damaged. If it does it just occasionally, then I'd suggest that that's just life. Joys of shooting at large aperture.
davidfarina
Gallery: 43 photos
Joined May 2013
Aug 06, 2014 11:11 |  #7
speedync wrote in post #17078369 (external link)
It is quite a time ago since ive noticed this on my 50L, but if i recall correctly ive also tried manual focus and didnt worked out a setting where my subject was sharp. Clearly it would not come out as a great picture because the subject was too far away and would be very small, but i had no time to change lenses and id rather have it small than no picture or as soft as ive got it...
1,301 views & 0 likes for this thread, 3 members have posted to it.
1605 guests, 142 members online
