Thread started 10 Aug 2014 (Sunday) 01:09
Flash exposure question
beegeeboy
Aug 10, 2014 01:09 |  #1
Hi all,
A simple question (probably!).
If I am in spot mode, av, flash it ettl, will the flash expose differently than if I'm in a different metering mode? For example, if I spot meter someone's face, which is darker than the surrounding area, will the flash just expose the face correctly?
Thanks in advance
David
Gear: A box with a hole; some tubes with glass in 'em
SmugMug (external link)
Phil ­ V
Joined Jan 2005
Aug 10, 2014 01:29 |  #2
beegeeboy wrote in post #17086890 (external link)
Hi all,
Thanks in advance
David
The flash metering mode is switchable between ETTL and CW Average, depending on your camera age average might be more reliable. You also have the option of Flash Exposure Lock.
But, to answer your actual question; No, the ambient meter mode doesn't affect the flash output.
website: South Yorkshire Wedding photographer in Doncaster (external link)
Twitter (external link)Facebook (external link)
OceanRipple
Joined Jan 2014
Aug 10, 2014 02:38 |  #3
+1
Switchable, for Flash algorithm, within the camera's flash menu (old bodies, as a CFn) - separate from the ambient metering pattern top-plate button.
And FEL forces a central spot (or cam's nearest to 'spot') metered pre-flash & lock (default 16secs).
Van ­ Gogh
Gallery: 118 photos
Best ofs: 5
Joined Jun 2013
Aug 10, 2014 08:19 as a reply to  @ OceanRipple's post |  #4
To answer your question, "No the camera mode doesn't effect the flash exposure mode".
The flash itself has a mode that you can change that affects the flash exposure method, but that another story and has nothing to do with camera exposure mode.
Camera - 2x5Dmk3, C100 mkii, 70D, 60D
Lenses - 24-70mm f2.8L II, 70-200mm f2.8L IS ii, 85mm f1.2L II, 35mm f1.4 ART, 100mm f/2.8L Macro IS
Lighting - 3 x 600EX RT's, Printer - Epson 3880
beegeeboy
Aug 10, 2014 16:12 |  #5
Thanks guys for the quick responses!
David
772 views & 0 likes for this thread, 4 members have posted to it.
1054 guests, 103 members online
