I now own a Canon 60D with a 70-300 L series that I use mostly for motorsport
photography. Looking to maybe upgrade to a 6D. Is there enough difference to jusify an upgrade or should I keep saving to upgrade higher. Any help greatly appreciated.
Aug 14, 2014 17:14 | #1 I now own a Canon 60D with a 70-300 L series that I use mostly for motorsport
jay125 the title fairy put me in therapy More info | Aug 14, 2014 20:37 | #2 First question is what is the 60D not doing for you? The 6D is an amazing body, however the frame rate is a little slower, 4.5 fps, than what you have with the 60D, so that is something to consider as you shoot action. The 6D is pretty capable for shooting sports, which has been documented in many threads on the forum. Your current lens will shine on the 6D, but with a little less reach, but you can adjust for that as well using your feet. So back to my original question...what is the 60D not doing for you?
monkey44 Senior Member 726 posts Likes: 15 Joined Jul 2003 More info | Aug 17, 2014 15:14 | #3 You know you're going from Crop to Full Frame, right? That will make a difference in the reach, but with the 70-300 might not matter as much as if you are shooting with shorter glass. Take that into consideration though in your evaluations.
SteezyB Member 43 posts Joined Jul 2014 More info | Aug 19, 2014 20:25 | #4 You should be investing in lenses, not a new body
watt100 Cream of the Crop 14,021 posts Likes: 34 Joined Jun 2008 More info | Aug 21, 2014 12:56 | #5 spudrace wrote in post #17096596 I now own a Canon 60D with a 70-300 L series that I use mostly for motorsport photography. Looking to maybe upgrade to a 6D. Is there enough difference to jusify an upgrade or should I keep saving to upgrade higher. Any help greatly appreciated. unless you need a full frame (better in low light?) then it's more advantageous investing in lens rather than another body
| Latest registered member is Monkeytoes 1356 guests, 164 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
