Thread started 15 Aug 2014 (Friday) 09:51
Setting ISO on Set button on 60d
blackgold59
Joined Feb 2013
Aug 15, 2014 09:51 |  #1
Hopefully this isn't a stupid question but I was wondering if there was a way to set this up on the canon 60d, I have this set up on my 6d.
If there is I can't find how to do it.
travisvwright
Gallery: 21 photos
Joined Feb 2013
Aug 15, 2014 09:53 |  #2
I'm not near my camera now but I think on my 600D I was only able to do this with ML.
I come here for your expert opinion. Please do not hesitate to critique or edit.
70D, 6D, Canon 135, Tamron 28-75 2.8, Tamron 70-200 2.8 VC, Canon 50 1.4, Canon 100 2.8 Macro, Canon 85 1.8, Canon 10-18 4.5 STM
Franklin NC Photographer Travis Wright (external link)
rrblint
Gallery: 84 photos
Joined May 2012
Aug 15, 2014 10:06 as a reply to  @ travisvwright's post |  #3
Apparently not, Custom function IV-2 only lists these as the possibilities:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/08/3/LQ_692897.jpg
Image hosted by forum (692897) © rrblint [SHARE LINK]
Mark
blackgold59
Joined Feb 2013
Aug 15, 2014 16:43 |  #4
Yeah, thanks! That's all I could see as well but thought maybe I was missing something.
Thanks again!
rrblint
Gallery: 84 photos
Joined May 2012
Aug 15, 2014 21:21 |  #5
travisvwright wrote in post #17097801 (external link)
Curiously the 600D does have ISO as one of the settable features:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/08/3/LQ_692965.jpg
Image hosted by forum (692965) © rrblint [SHARE LINK]
Mark
JWdlft
Joined Feb 2013
Aug 16, 2014 11:20 as a reply to  @ rrblint's post |  #6
I'm just curious why you want to switch the ISO button to the Set button from the ISO button above the top LCD screen.
apersson850
Gallery: 35 photos
Aug 16, 2014 13:27 as a reply to  @ JWdlft's post |  #7
If it works as it does with my 1DX, then there is the advantage that you can look through the viewfinder, press the SET button and roll the dial. Then in real time you'll see how your aperture and/or time will change as you modfiy the ISO value.
You can see the ISO value change if you use the normal ISO button, but not immediately how it affects exposure.
Anders
JWdlft
Joined Feb 2013
Aug 16, 2014 14:25 |  #8
apersson850 wrote in post #17100078 (external link)
Thanks. That could be very interesting, one of those things to think about when upgrading.
travisvwright
Gallery: 21 photos
Joined Feb 2013
Aug 17, 2014 05:44 |  #9
JWdlft wrote in post #17099875 (external link)
(On the 600D) In manual,
to adjust SS your thumb presses nothing and your finger rolls the dial,
to adjust AV your thumb presses the AV button and your finger rolls the dial,
to adjust ISO your finger pushes the ISO button and your thumb uses the left and right arrows to adjust.
It feels backwards. Having it so thumb chooses what changes and finger rolls the dial no matter which of the 3 you want to change keeps it nearly subconscious.
watt100
Aug 17, 2014 05:58 |  #10
right, setting the ISO using the regular ISO button is easy, why change it
MakisM1
Gallery: 50 photos
Joined Dec 2011
Aug 17, 2014 09:17 |  #11
I use the SET button to select center point autofocus. Then, using the D-pad for the outer focus points is an intuitive operation. Pressing the SET twice chooses all points autofocus (never use).
Gerry
hiketheplanet
Joined May 2013
Aug 17, 2014 09:25 |  #12
My ISO is set to the SET button as well. You don't lose the ISO button up top, it just gives you another way to set it. It works by pressing and holding the SET button, and simultaneously moving the top wheel left or right to adjust. I find this quicker than using the top button because if I'm adjusting exposure, my thumb is already on the dpad/thumb-wheel.
1,844 views & 0 likes for this thread, 8 members have posted to it.
506 guests, 119 members online
