Thread started 15 Aug 2014 (Friday) 15:40
Adorama Rovelight RL 600, thoughts?
RickFL
Aug 15, 2014 15:40 |  #1
I see this strobe on flashhavoc. Looks very interesting. Under $600 for 600W with remote power control and lithium battery power built in. Thoughts everyone?
6D gripped :: 17-40L :: 135L :: 70-200 f/2.8L II IS :: Tokina 24-70 f/2.8 :: 50 f/1.4 :: CL 360 (x 2)
My website: rickalonzophoto.com (external link)
My Instagram @sosofreshnsoclean (external link)
OceanRipple
Joined Jan 2014
Aug 15, 2014 17:06 |  #2
I think it's interesting.
It seems based on the Jinbei HD 600, but there may already be a version II of that Strobe.
http://www.foto-morgen.de …-600Ws-Fernsteuerung.html (external link)
In translation, from the 'II' version blurb:
"Please note that the Super Sync / HSS to use function separately sold remote trigger such as the YN-622 or Pixelking is required ! In addition, the Super Sync mode only works at maximum power."
So, it's a version of the 'Long burn - Early trigger hack'. Theoretically, you could change power with the Jinbei remote but trigger with say an Odin using ODS (at 1/1) etc.
You get one remote with each unit, so, using an off brand trigger, the Jinbei channels would give you ?16 quasi Groups.
I'll be following developments . . .
adammazza
Aug 18, 2014 17:04 as a reply to  @ OceanRipple's post |  #3
looks interesting. I was going to pick up an Einstein for the fast flash duration, but this may be a better option.
Canon 5Dm3, Fuji X100T, Fuji X-T1, Fuji X70
Canon 70-200mm L F/2.8 IS
Canon 24-105mm L F/4.0 IS
Sigma 35mm F/1.4, Sigma 85mm F/1.4
Fuji 16mm F/1.4, Fuji 35mm F/1.4, Fuji 56mm F/1.2, Fuji 16-55 F/2.8
shutterbug ­ guy
Aug 18, 2014 18:42 |  #4
RickFL wrote in post #17098530 (external link)
I see this strobe on flashhavoc. Looks very interesting. Under $600 for 500W with remote power control and battery power built in. Thoughts everyone?
I like the stobe and it's features. One lingering question I have though is how is the color balance on this thing as you work it at different power settings? The thing that the Einsteins have going for them is a consistant color balance, regardless of the power setting.
RickFL
Aug 18, 2014 19:21 |  #5
I agree, there are details we still don't know.
In case anyone missed this update...
Flash Havoc says:
August 18, 2014 at 9:59 pm
UPDATE – Jinbei have confirmed the current Flashpoint Rovelight’s have a HSS mode which can be turned on when the flash is set to full power.
This mode increased the flash duration at full power.
A HSS enabled TTL trigger like the YN-622C-TX, Phottix Odin, Pixel King Pro etc would need to be used to trigger the flash when using this mode.
Also there is a “Fire all Channels” option on the transmitter unit. So channels could be used as a workaround for groups.
- See more at: http://flashhavoc.com …0-now-available/#comments (external link)
OceanRipple
Joined Jan 2014
Aug 19, 2014 06:15 |  #6
Tx. So really there's probably no real version II, just an update of firmware beyond a given build date. If buying a Jinbei HD 600, how do you tell which version you are buying? I assume no user enabled Firmware changing.
Still it's worth watching if the manufacturer & suppliers get behind this product, as perceived from, in my case, Europe.
elv
Aug 25, 2014 06:03 as a reply to  @ OceanRipple's post |  #7
The RoveLight just arrived here, and as it turns out this is the very latest model with the full HSS mode, which operates from Full power all the way down to 1/16th !!
You hold the top 2 left buttons down, and this engages the HSS mode. A HSS symbol is then displayed on the LCD screen (top right).
TTL triggers like the YN-622, or Phottix Odin etc are required to enable this mode.
IMAGE: http://flashhavoc.com/wp/wp-content/uploads/2014/08/FP_RoveLight_4_a700.jpg
FLASHHAVOC.COM (external link)
OceanRipple
Joined Jan 2014
Aug 25, 2014 11:55 |  #8
OK, Tx!
So you can differentiate the different Jinbei HD 600 rebrands by studying the printed items on the back face of the unit. Version one was not the same, missing the 'spark H' item.
If this actually does what it claims to do, then it's a tempting proposition. I'd really like to hear your thoughts on actually using this unit - ODS included!
elv
Aug 25, 2014 12:33 as a reply to  @ OceanRipple's post |  #9
So far I just tried with the regular YN-622C, and got all the way to 1/8000th with a clean frame, even at 1/16th power.
That was outside though, I need to test properly on a white wall to see exactly what the results really are, and if timing adjustment has any advantage etc.
Robsphoto
Gallery: 6 photos
Joined May 2011
Aug 25, 2014 13:25 |  #10
I am betting Godox and youngnou will followup with an better model!!
Happy Shooting:lol:
adammazza
Aug 25, 2014 17:06 as a reply to  @ Robsphoto's post |  #11
Well, tried to resist. Couldn't...Got 2 and 2 extra batteries. Now need to sell my 2 600w Mettle lights....
flowrider
Gallery: 124 photos
Aug 25, 2014 18:59 |  #12
I'm in the same boat Adam. Was going to get a VML to run my Flashpoints but now I'm thinking one of these instead.
~Steve~
~ My Website-stevelowephoto.com (external link) ~ Facebook (external link)
Feedback Feedback Feedback
gremlin75
Aug 25, 2014 22:00 |  #13
With the coupon code elv has up on his site right now it's kind of hard to pass them up!!
sportmode
Joined Nov 2010
Aug 25, 2014 22:04 |  #14
HSS, modeling light, 600W, remote, $400. Hard to pass up if I didn't already had my investment in lights...
5D Mark III, 6D, EOS-M 22mm f/2 | 24-70mm f/2.8L II | 50mm f1.4 | 100L | 70-200mm f/2.8L IS II | Rokinon 8mm Fisheye
krispyk
Gallery: 47 photos
Joined Aug 2012
Aug 25, 2014 23:14 as a reply to  @ sportmode's post |  #15
Elv, if the battery is run down can you plug it in and shoot with them plugged in? I was ready to pull the trigger on one Einstein and Vegabond mini but I could get two of these and so I'm still on the fence. And how long does it take to charge? Thanks.
krispyk
https://davidjohnson.s​mugmug.com
Canon 5d Mk iii | Canon 70D | 24-70mm 2.8L | 100mm 2.8L Macro | 70-200mm F4L IS | 50mm 1.8 | ef-s 18-135mm 3.5-5.6 IS | Canon 200mm 2.8L v1 | Tamron 150-600mm V1
459,550 views & 481 likes for this thread
Latest registered member is holmesidepi
837 guests, 271 members online
