Thread started 18 Aug 2014 (Monday) 03:03
1st tracked shot
Desertraptor
Gallery: 212 photos
Aug 18, 2014 03:03 |  #1
Only 20 secs at ISO1600
IMG_6849-M42 (external link) by Peter Ede (external link), on Flickr
Peter
Canon 6D|60D|40D
Lens 10-22mm f2.8|50mm f 1.8|100mm f2.8 Macro
24-70mm f2.8|L100-400mm f4.5-5.6L
Flash 430EX II
Telescope Skywatcher 600mm ED80 f7.5 GEM EQ3
SteveInNZ
Aug 18, 2014 04:31 |  #2
M42 is an astrophotography milestone. Congratulations.
Steve.
"Treat every photon with respect" - David Malin.
Desertraptor
Gallery: 212 photos
Aug 18, 2014 06:33 |  #3
Seems since having a telescope Adelaide skies are filled with clouds. But only when I'm home
Peter
Canon 6D|60D|40D
Flash 430EX II
legoman_iac
Aug 19, 2014 07:45 |  #4
That's why telescopes are also called "cloud magnets". Nice shot. How are you going balancing the scope with camera?
2x 50d: with 17-85mm f4-5.6, 100mm Macro USM, 50mm f1.8, 2x Sigma 30mm f1.4, 55-250mm (kit lens), Canon 100-400mm L, Tamron 200-400mm f5.6, Samyang 8mm. 480mm refactor with HEQ5. Home made beamsplitter stereo rig.
Desertraptor
Gallery: 212 photos
Aug 19, 2014 20:25 |  #5
Thanks Legoman
I could use another weight but so far it's doing ok with the weight I have.
Might swap from 60D to G1X
the weight is mostly an issue when I go vertical with the weight dragging on the focus. Easy enough to work around that by not aiming vertical. I figure if I stay with in 0 - 60deg I'm fine. Limiting but the sky moves :) Maybe a dual speed focuser later unless there's something else
Peter
Canon 6D|60D|40D
Flash 430EX II
1,158 views & 0 likes for this thread, 3 members have posted to it.
1st tracked shot
930 guests, 117 members online
