Thread started 20 Aug 2014 (Wednesday) 05:21
Does flash contain infra red
adrian5127
Aug 20, 2014 05:21 |  #1
Hi
I am doing a photoshoot with a horse that has an allergy to sunlight, particularly infra red.
Do you think I will be okay using flashlights (600s)
Adrian
SE UK Thread here***Kit***smugmug (external link)
Wedding photography kent (external link)
Wedding photographer kent (external link)
apersson850
Aug 20, 2014 06:05 |  #2
There's most likely parts of the IR spectrum present in flash light as well. But the duration is short.
Anders
Luckless
Joined Mar 2012
Aug 20, 2014 06:21 |  #3
Are you sure the issue isn't the UV? (IR is essentially heat radiation and is exceptionally hard to avoid. Unless the animal lived in a climate controled dark cave I wouldn't expect one with an issue to IR to survive long.)
Xenon flash will produce a noticeable output of both UV and IR and everything in between, but in very short durations. UV can be filtered for the most part, but controlling IR output would be a lot more tricky.
Talk to the people who handle the animal. If it has a serious issue with lights, then I would hope they have access to the gear to measure the levels of new equipment/inspect existing stuff, and should be able to help you test your kit before hand.
Canon EOS 7D | EF 28 f/1.8 | EF 85 f/1.8 | EF 70-200 f/4L | EF-S 17-55 | Sigma 150-500
Flickr: Real-Luckless (external link)
365 views & 0 likes for this thread
Latest registered member is zinndeadly
2275 guests, 215 members online
