Looking for a good reverse ND filter to fit my Lee system. It does not appear that Lee make one. Suggestions greatly appreciated
Aug 22, 2014 15:37 | #1 Looking for a good reverse ND filter to fit my Lee system. It does not appear that Lee make one. Suggestions greatly appreciated Canon 5D3, 60D, 70-200 L f4 IS, 17-40L,16-35f4, 24-105L,100 f2.8, 85 f/1.8, 55-250 IS, 400 f/5.6, Ziess 21 2.8, canon 1.4, 430EX www.flickr.com/photos/maggiesguy
Aug 22, 2014 15:38 | #2 Reverse? As in flipping it upside down doesn't work for your needs?
Ok, I see what you're after, something that is darker on the grad edge and gets lighter as it goes up. Cokin and hitech and some of the others all fit the lee system from what i understand
Aug 22, 2014 16:29 | #4 singh ray and hitech make one. I use the hitech one, and optically, no issues. Sony A7siii/A7iv/ZV-1 - FE 24/1.4 - SY 24/2.8 - FE 35/2.8 - FE 50/1.8 - FE 85/1.8 - F 600/5.6 - CZ 100-300 - Tamron 17-28/2.8 - 28-75/2.8 - 28-200 RXD
vengence Goldmember 2,103 posts Likes: 108 Joined Mar 2013 More info | Aug 22, 2014 16:42 | #5 I'd love a reverse ND filter! Too bad it breaks physics...
Aug 23, 2014 01:07 | #6 How about stacking existing Lee filters as shown here:
Snydremark my very own Lightrules moment More info | The stacking trick works in a pinch, but it would be much nicer to have an individual filter on hand if you're using it a lot. - Eric S.: My Birds/Wildlife
Aug 23, 2014 10:31 | #8 I'm going to offer an alternative to the reverse GND -LightRoom. LR's grad tool combined with the other tools is much more flexible than a lens filter and it doesn't permanently change your original exposure. Get a good initial exposure (ETTR), if conditions are right make a bracket or two just for good measure, and take it into LR. Canon 7d MkII, Canon 50D, Pentax 67, Canon 30D, Baker Custom 4x5, Canon EF 24-104mm f4, Canon EF 100mm f2.8 Macro, Canon EF-S 10-22mm f/3.5-4.5, 70-300mm f/4-5.6 Di VC
basketballfreak6 Goldmember More info | Aug 23, 2014 10:50 | #9 rgs wrote in post #17113087 I'm going to offer an alternative to the reverse GND -LightRoom. LR's grad tool combined with the other tools is much more flexible than a lens filter and it doesn't permanently change your original exposure. Get a good initial exposure (ETTR), if conditions are right make a bracket or two just for good measure, and take it into LR. Now put your grad line anywhere you want. Use two or three grad lines. Use the adjustment brush to fill any smaller areas. Adjust not only exposure but contrast, saturation, clarity and other parameters either up or down. None of this can be done in the field and, if you exposed to the right and did a bracket, your highlights should be good and you can always use PS to blend your bracket for better shadows if you need to. No expensive filters, no image files permanently altered, and less stuff to carry into the field. And, if you can't do it in LR, you will have a much better idea of exactly what you DO need in the field. bracketing is probably fine for short exposures, but for long exposures (which happens often during sunrise/set or for effect) you can potentially run into issues especially when light/conditions can change in very short time that was 90 second exposure, the clouds darting through above was there for a very brief moment, timed it wrong and it's gone on top of that i am not that great at editing, barely know how to use PS (i use lightroom 99% of the time) but then that's on me, YMMV, i try to get the best single file to work with for me straight up instead of having to worry about blending and all that stuff later, again YMMV FWIW, i am using singh ray 4 stop reverse grad, very happy with the IQ except it can sometimes give purple casting, but pretty easy fix though recently acquired a lee small stopper and 105mm cpl as well, can't wait to put them to use soon ![]() https://www.tonyliuphotography.com.au/
Aug 23, 2014 11:32 | #10 My post was about using LR tools. I only mentioned brackets as a fail safe when conditions allow. 4 stops is too much for LR which is why I said learning to use LR tools will help you know when you REALLY DO need a filter. In most cases I consider ND grads to be a holdover from film technique but in some they are still needed. Canon 7d MkII, Canon 50D, Pentax 67, Canon 30D, Baker Custom 4x5, Canon EF 24-104mm f4, Canon EF 100mm f2.8 Macro, Canon EF-S 10-22mm f/3.5-4.5, 70-300mm f/4-5.6 Di VC
Aug 23, 2014 14:16 | #11 basketballfreak6 wrote in post #17113104 bracketing is probably fine for short exposures, but for long exposures (which happens often during sunrise/set or for effect) you can potentially run into issues especially when light/conditions can change in very short time like this pic for example: Manly Sunrise that was 90 second exposure, the clouds darting through above was there for a very brief moment, timed it wrong and it's gone on top of that i am not that great at editing, barely know how to use PS (i use lightroom 99% of the time) but then that's on me, YMMV, i try to get the best single file to work with for me straight up instead of having to worry about blending and all that stuff later, again YMMV FWIW, i am using singh ray 4 stop reverse grad, very happy with the IQ except it can sometimes give purple casting, but pretty easy fix though recently acquired a lee small stopper and 105mm cpl as well, can't wait to put them to use soon ![]() did you really use a reverse GND for this shot? background looks like it was close to blowing out. Image hosted by forum (693598) © Charlie [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Sony A7siii/A7iv/ZV-1 - FE 24/1.4 - SY 24/2.8 - FE 35/2.8 - FE 50/1.8 - FE 85/1.8 - F 600/5.6 - CZ 100-300 - Tamron 17-28/2.8 - 28-75/2.8 - 28-200 RXD
Aug 23, 2014 14:51 | #12 Charlie wrote in post #17113417 For example, I have a shot with exactly 4 stops difference between them, one exposed for the sky during sunset, and even if I exposed to the right, there'd probably be 3 stops difference. Reverse GND would be great for this scenario, but unfortunately, it doesnt fit this particular lens. Well I had a little play in PS. It took about 2 minutes to blend the two to get the horizon of the darker one on the lighter one. Here's the result. The second is a little additional local work in LR. Remember I was working with your small jpegs. Working on full sized RAW would be easier and more effective. This illustrates what I was saying, those ND grads just aren't really needed very often. Image hosted by forum (693599) © rgs [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Image hosted by forum (693600) © rgs [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Canon 7d MkII, Canon 50D, Pentax 67, Canon 30D, Baker Custom 4x5, Canon EF 24-104mm f4, Canon EF 100mm f2.8 Macro, Canon EF-S 10-22mm f/3.5-4.5, 70-300mm f/4-5.6 Di VC
Aug 23, 2014 15:14 | #13 rgs wrote in post #17113455 Well I had a little play in PS. It took about 2 minutes to blend the two to get the horizon of the darker one on the lighter one. Here's the result. The second is a little additional local work in LR. Remember I was working with your small jpegs. Working on full sized RAW would be easier and more effective. This illustrates what I was saying, those ND grads just aren't really needed very often. Oh, I could have saved you the trouble I do have a set of ND grads, pretty complete set, but I also tend to avoid them. I guess if the scene is really straight forward, or too tricky for HDR, then I'de use them. Sony A7siii/A7iv/ZV-1 - FE 24/1.4 - SY 24/2.8 - FE 35/2.8 - FE 50/1.8 - FE 85/1.8 - F 600/5.6 - CZ 100-300 - Tamron 17-28/2.8 - 28-75/2.8 - 28-200 RXD
basketballfreak6 Goldmember More info | Aug 23, 2014 19:17 | #14 rgs wrote in post #17113161 FWIW, I would want the shadows in your image a stop or 2 darker which would mean no grad for me. I do like yours as well. ETTR allows us to hold detail in light areas and process for shadows. That's much easier to do than it was with film. oh yea definitely, it all open to individual's interpretation of their shots Charlie wrote in post #17113417 did you really use a reverse GND for this shot? background looks like it was close to blowing out. hey Charlie, i did, 4 stop as well lol https://www.tonyliuphotography.com.au/
Maxdave Goldmember More info | Aug 25, 2014 06:34 | #15 Charlie wrote in post #17112080 singh ray and hitech make one. I use the hitech one, and optically, no issues. I too have a set of three Hitech RGND's (1, 2 and 3 stop), and also no optical problems. 5D3,1D4,S90,6S&Moment Lenses,Hero4Silver,GPS-E2,2x580EX,430EX,90EX,EF16-35L f/4 IS,Samy SYTS24-C 24TS,EF24-105L IS,EF50 f/1.4,EF70-200 f/4L IS,EF300 f/4L IS,EF100-400L I IS,Kenko DGX 1.4X,Canon 2X TC Mk II, RRS&Pro-Media L-Brackets,Manfrotto MHXPRO-3WG & Roller 50,Sirui 306&K-20,Giottos MT-7371&MH-3300,Velbon ElCarmagne 530,CamRanger,Phottix&Canon Remotes,Lowepro Backpack,ThinkTank Retro 20&Modular System,OpTech straps,Lexar/San Disk Cards
| Latest registered member is Niagara Wedding Photographer 1338 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
