Can you use an Avenger D600 boom on Matthews Hollywood Century C stand? Is the fit at the connection point "spigot" good or should you match Avenger booms with Avenger stands and Matthews booms with Matthews stands?
silvermesa1 Member 145 posts Likes: 17 Joined Aug 2013 Location: Columbia, Mo. USA More info | Aug 23, 2014 08:34 | #1 Can you use an Avenger D600 boom on Matthews Hollywood Century C stand? Is the fit at the connection point "spigot" good or should you match Avenger booms with Avenger stands and Matthews booms with Matthews stands?
TheLoftStudios Goldmember 1,072 posts Likes: 9 Joined Oct 2009 Location: Houston, Texas More info | Aug 23, 2014 10:57 | #2 Yes, you can use the Matthews C-Stand with the Avenger D-600 Boom Arm….. MARK
abbadon31 Goldmember More info | Aug 23, 2014 11:34 | #3 It will mount on any stand as long as you have a 5/8 spigot I AM SHOM
Whortleberry Goldmember 1,719 posts Likes: 53 Joined Dec 2011 Location: Yorkshire, England More info | Aug 23, 2014 13:08 | #4 There ARE tiny differences among the supposedly standarised spigots on lightstands. Some are 5/8th inch while some are 16mm - only 1/8th mm difference nominally. However, factor in machining errors and you may just find that some spigots are a tad tight in the "matching" sockets. I haven't found any pattern to this so it's not a matter of XYZ-brand spigot doesn't fit into ABC-brand socket. Phil ǁ Kershaw Soho Reflex: 4¼" Ross Xpres, 6½" Aldis, Super XX/ABC Pyro in 24 DDS, HP3/Meritol Metol in RFH, Johnson 'Scales' brand flash powder. Kodak Duo Six-20/Verichrome Pan. Other odd bits over the decades, simply to get the job done - not merely to polish and brag about cos I'm too mean to buy the polish!
| Latest registered member is Monkeytoes 1323 guests, 169 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
