Bob_A wrote:
Adobe PS has no ability to open Raw files and convert them to jpeg. For Adobe PS CS2 this is done using a companion application called Adobe Camera Raw (ACR). So, if I save the Raw files to my hard drive and use File -> Open in PS, they actually open in ACR, not PS. It's the same application that opens up if you click on the Raw file in Adobe Bridge.
If you are using PS Elements 2.0, I don't believe that a version of ACR is available.
To edit images in PS that have been taken in Raw format you need to convert them first to Tiff or jpeg first using something like:
ACR (Adobe Camera Raw)
Rawshooter Essentials (there is a free version available)
Digital Photo Professional
EOS Viewer Utility
just to name a few, and all will do a decent job.
Well, all plug-ins are programs. They just work within another host application, so that is a moot point.
The Adobe RAW plug-in does not convert RAW to another file format. I bring that up because I think that would confuse someone like X-WoodButch who is trying to get started with RAW workflow. Adobe RAW is just an 8bi file format plug-in that allows Photoshop, (or another host application), to import the file just like the 8bis that allow the importation of Png, Gif, Tiff or many other file formats.
You can confirm that the file is imported in Cr2 RAW format by opening the file in Photoshop and going to the file's EXIF data. It will show that the file is a CR2. You can also look at the file name extension on the image.
You can edit a CR2 all you want, you just can't save it in RAW. That's where the other file formats come into play.
Regards,
