Thread started 27 Aug 2014 (Wednesday) 07:57
1.4 teleconverter with 400 5.6
Sgt.
Gallery: 56 photos
Aug 27, 2014 07:57 |  #1
So I thought the 1.4 mkiii tele should autofocus on 5 D mkiii with the 400 5.6?
Any body try this?
Iain
7D MKII
Another minion in the Pondrader fan club
JWdlft
Joined Feb 2013
Aug 27, 2014 09:02 |  #2
According to Canon website (external link) the answer is yes, with firmware version 1.2.3. Not all points, but yes.
There's a link to the download on that page.
Canon ­ Bob
Aug 27, 2014 11:59 as a reply to  @ JWdlft's post |  #3
Just tried it and it works....putting the combination on the body locks you into the centre point.
Bob
1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
Eyal
Joined May 2011
Aug 27, 2014 15:22 |  #4
5D3 can now give you AF when using VF with lenses at minimum of F/8.
The 400 F/5.6 with 1.4x will give you 540mm F/8, which works with the 5D3.
Note that the focus points will be less accurate outside the centre with this setup.
5DMarkIII+Grip | Extender 1.4x III / 2x III
16-35mm F/2.8L II | 24-70mm F/2.8L II | 70-200mm F/2.8L IS II
Σ 50mm F/1.4 | 85mm F/1.2L II | 100mm F/2.8L IS Macro | 135mm F/2L | 300mm F/2.8L IS
Canon ­ Bob
Aug 27, 2014 17:34 |  #5
Eyal wrote in post #17121246 (external link)
I don't think you can even select focus point outside the centre once you mount the combination....I couldn't when I tested it earlier.
Bob
Sgt.
Gallery: 56 photos
Aug 29, 2014 14:19 |  #6
Thanks, I had to update my firmware!!
Iain
7D MKII
1,969 views & 0 likes for this thread, 4 members have posted to it.
922 guests, 118 members online
