I can't seem to get my color right. What is wrong with this image regarding color tone?
Aug 27, 2014 17:24 | #1 I can't seem to get my color right. What is wrong with this image regarding color tone? Image hosted by forum (693925) © mdaddyrabbit [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Website
Davenn Senior Member More info | Aug 27, 2014 19:06 | #2 Hi A picture is worth 1000 words
Aug 27, 2014 20:23 | #3 I wish I could post the raw file here. I am using Lightroom and PS CS6. I desaturated to correct the whole image from a pink tone. Website
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Aug 27, 2014 21:15 | #4 A 'pink tone' might be an imbalance in the Tint (Magenta-Green axis of the color circle)...fix that, rather than reducing Saturation. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
DanMarchant Do people actually believe in the Title Fairy? 5,635 posts Gallery: 19 photos Likes: 2058 Joined Oct 2011 Location: Where I'm from is unimportant, it's where I'm going that counts. More info | Aug 27, 2014 23:31 | #5 mdaddyrabbit wrote in post #17121755 I wish I could post the raw file here. You could always post it to drop box or another file sharing site and post the link here. Dan Marchant
Lowner "I'm the original idiot" 12,924 posts Likes: 18 Joined Jul 2007 Location: Salisbury, UK. More info | Aug 28, 2014 02:28 | #6 Wilt wrote in post #17121828 A 'pink tone' might be an imbalance in the Tint (Magenta-Green axis of the color circle)...fix that, rather than reducing Saturation. Yes, very definitely the wrong solution to your problem. Show us the unaltered shot if you can. Richard
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Aug 28, 2014 04:22 | #7 The image is in ProFoto RGB but has no embedded profile. I have no idea how you managed to get a ProFoto image with no embedded profile. The problem is your workflow, but tracking it down would be tricky. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
kirkt Cream of the Crop More info | Aug 28, 2014 09:48 | #8 ^^ Tim is likely correct. If you open the image in PS and ASSIGN the ProPhoto profile, the color and tone appear more reasonable. After assigning ProPhoto, CONVERT to sRGB and do your thing. Kirk
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Aug 28, 2014 11:45 | #9 There is nothing in that image that would require the use of ProPhoto RGB, it wouldn't fill 50% of sRGB. LR may use an ultra wide gamut working space because it has to cover all possible contingencies, both in terms of subject matter and in terms of display media, but staying in ProPhoto RGB in PS is a choice made by the photographer, either by commission or omission, and he needs to know that choosing wrong can have consequences. Elie / אלי
Aug 28, 2014 17:00 | #10 How does this look ? Image hosted by forum (694003) © Amamba [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. There's not much to work with, unfortunately. The file is small res and the highlights are blown to bits. Try downloading a trial of Photo Ninja, for me it works the best in getting a good skin color. I think you need to take the original - RAW if you have it - and dial temp down just a bit, for starters. Ex-Canon shooter. Now Sony Nex.
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Aug 28, 2014 17:52 | #11 Amamba wrote in post #17123323 How does this look ? Still very wrong. The problem is the color profile, assign ProFoto RGB and it looks fine. Image hosted by forum (694008) © tim [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
http://1drv.ms/1vTAM58 Website
Aug 28, 2014 20:07 | #13 kirkt wrote in post #17122606 ^^ Tim is likely correct. If you open the image in PS and ASSIGN the ProPhoto profile, the color and tone appear more reasonable. After assigning ProPhoto, CONVERT to sRGB and do your thing. Was this image converted from raw in Lightroom or ACR (into the ProPhoto color space) and then saved in ProPhoto but using something like Save For Web or otherwise not embedding the profile? If you are going to save your images for web display in something other than sRGB, you are going to need to embed the color space tag in the image so color aware applications can render it correctly. Many photo sharing sites strip the color profile tag out of the image anyway, which will foil your attempts to post an image in something other than sRGB. It is best to convert to sRGB and then save that version for web display - applications that are not color aware will most likely assume sRGB, so the image will look "correct" on almost anything. kirk
Website
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Aug 28, 2014 20:49 | #14 Just be careful with your color profiles and you'll be fine, like I said above. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
kirkt Cream of the Crop More info | Aug 29, 2014 08:11 | #15 Here is an example of what can go wrong if you do not pay attention to your color profiles. I converted your linked file into the ProPhoto color space. I made thee versions: Image hosted by forum (694038) © kirkt [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Image hosted by forum (694039) © kirkt [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Kirk
| Latest registered member is semonsters 1511 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
