Thread started 18 Feb 2006 (Saturday) 17:11
Comments on my lighting?
dsze
Joined May 2004
Feb 18, 2006 17:11 |  #1
From last night's 5th-6th grade school dance, obviously a Western theme. No, those last 2 aren't REALLY small 5th graders! At the end, I threw my own little girls up on the saddle, before tearing down. I posted a couple of these in another thread, but got no responses. Maybe they are that bad:o I was hoping to learn a little about lighting from this.
I'm more of a PJ style of photographer and this was my first try at a semi-studio-style setup. I had to keep the lighting general enough to 'keep 'em coming through' without having to make any adjustments to the lighting. Contructive comments?
#1
#2
#3
thanks,
-daniel
"Life is not measured by the number of breaths we take, but by the moments that take our breath away."
-Gear List-
Dante ­ King
"Cream of Corn" BurgerMeister
Joined Jan 2005
Feb 18, 2006 17:21 |  #2
howdy,
purdy nice there tex! I recon that them thar youngin's were downright grateful for such lovely pics.
Dante
I am not an Lcoholic. Lcoholics go to meetings!
Ruffneck
Feb 18, 2006 17:23 |  #3
The pictures are slightly flat, but they look good! Perhaps they could have benefitted from being moved further away from the background. Of course I assume that space is always an issue.
Canon 20D & 60D, Canon70-200mm L 4.0, Canon 17-40mm L 4.0, Canon 24-70 L, 2.8, Canon 28-135mm IS, Canon 85mm f1.8, Canon 100mm Portrait Lense, Tamron 17-50 VC, Sigma 15-70mm 2.8-4 HSM, Canon Speedlite 580Ex, Canon Speedlite 420Ex, 3 AB800's, ...and a whole host of other odds and ends!
dsze
Joined May 2004
Feb 18, 2006 17:33 as a reply to  @ Dante King's post |  #4
Dante King wrote:
howdy,
I think I'll take that as a compliment ;)
-daniel
-Gear List-
dsze
Joined May 2004
Feb 19, 2006 09:07 |  #5
Ruffneck,
Yeah, they are a bit flat... Thats probably because I had to keep the lighting rather uniform for some of the larger groups and the lack of a hairlight (I just had a reflector back there and off to the side).
Space was an issue as I was set-up right in the main entrance to the school...so everyone was walking behind me and in-front of my table... not the best set-up. So, it limited the distance the subjects could be from the backdrop. How much further away would you recommend when shooting f9-f11?
thanks,
-daniel
-Gear List-
symes
Feb 19, 2006 09:47 |  #6
you know a strobe set up behind the Hay would have likely done the trick...created that separation for you...
Cheers,
Symes
Symplicity Photography (external link) Symplicity Glamour (external link)
5D Mark II; 1D Mark II; 17-40L; 24-70 2.8L; 70-200 IS 2.8L
dsze
Joined May 2004
Feb 19, 2006 10:22 as a reply to  @ symes's post |  #7
Cheers,
Yes, I think you're right. Next time. Hopefully, their parents will be happy with these though. I only charged $4/5X7.
-daniel
-Gear List-
dsze
Joined May 2004
Feb 20, 2006 08:00 |  #8
symes,
If you were to put a light back there, what would you use? Drop another speedlite back there or something like an A.Bee 400, or something else? The set-up I used consisted of only speedlites and umbrellas with one reflector. I'd like to keep my set-up very portable, because I mostly do location shoots, but I realize there are limitations with using speedlites (and expensive).
-daniel
-Gear List-
symes
Feb 20, 2006 10:42 as a reply to  @ dsze's post |  #9
dsze wrote:
symes,
I am by no means a pro so I really can't say what would work...but you might have enough with the speedlight behind...It depends what you need as portable...I have a portable power kit but it was bloody expensive, I know that...
If I were you I would experiment a little with the set up before hand...you seem to have two lovely daughters that would fit the bill as models...:)
Cheers,
Symes
Titus213
Feb 20, 2006 13:43 |  #10
Very nice work. The background is a bit dark. I wonder how much of that might have been caused by the bright reflections off the saddle work? I find lighting the background a problem too. Your backgrounds came up nicely with some shadow/highlights adjustment.
Dave
Perspiring photographer.
md_129
Joined Nov 2005
Feb 21, 2006 18:42 |  #11
Photos look great...
looks like the little girl in the white shirt in number 2, reflected a lot of your flash, maybe try placing her or the flash in a different position.
Mike
Current Projects:
http://webdoctus.com/ (external link)
dsze
Joined May 2004
Feb 22, 2006 06:31 as a reply to  @ md_129's post |  #12
Good point...while positioning them quickly, I didn't even think about the white shirt and changing her placement.
thanks!
-daniel
-Gear List-
JMHPhotography
Feb 22, 2006 21:06 |  #13
keeping it in perspective... you are only charging $4.00 for a 5x7. I think these look great when considering that and the space constraints as well. I think they are good regardless.
~John
(aka forkball)
Have a peek into my Gearbag. and My flickr (external link)
editing of my photos by permission only. Thanks
Amorous
Feb 23, 2006 16:38 as a reply to  @ JMHPhotography's post |  #14
Overall, I think you got pretty good results. Like others said, lighting the BG will be better. How many speedlites did you use?
My web site: http://kaitcilla.smugm​ug.com/ (external link)
Los Angeles area local photography group: http://lashooters.org (external link)
dsze
Joined May 2004
Feb 23, 2006 18:49 |  #15
I used 2 speedlites, one on each side shooting into a silver umbrella about 7.5 ft up. I had another speedlite on camera, but only to trigger the other 2. The one on camera was set to not flash.
-daniel
-Gear List-
1,751 views & 0 likes for this thread, 8 members have posted to it.
998 guests, 103 members online
