Just taken delivery of a new Pixma Pro-100 for a new studio i'm opening so client can have prints made
The quality of this printer is staggering.. It really is. stands well up to the quality of any wet lab printer I have used in the past..
Rushmore Goldmember 1,116 posts Likes: 82 Joined Nov 2012 Location: Leamington Spa, Warwickshire, UK More info | Aug 30, 2014 06:03 | #1 Just taken delivery of a new Pixma Pro-100 for a new studio i'm opening so client can have prints made Reppin the 5D iii and 7D with some lenses and some lights
DanMarchant Do people actually believe in the Title Fairy? 5,634 posts Gallery: 19 photos Likes: 2056 Joined Oct 2011 Location: Where I'm from is unimportant, it's where I'm going that counts. More info | Aug 30, 2014 22:46 | #2 Friend of mine bought one and loves it. Dan Marchant
I think it is hard to go wrong with modern printers. I had a Pro9500II which is several years old and replaced it with a 3880. I can't tell the difference in quality. I'm sure I haven't used the best labs (not Costco or Walgreen's though), but I also think they are as good as any lab print I've had. Certainly similar to Adoramapix. Edward Jenner
tgara Goldmember 2,336 posts Likes: 8 Joined Sep 2007 Location: Connecticut, USA More info | Good to hear, considering the Pro-100 is the cheapest and least capable of Canon's Pixma Pro offerings (not meant to be a slight to your printer mate, just stating facts relating to the Pixma pro lineup). If it's as good as you say, the higher-end models should blow you away. I'm considering upgrading my Epson R1900 to a Pro-10. EOS 5D Mark III
agedbriar Goldmember 2,657 posts Likes: 398 Joined Jan 2007 Location: Slovenia More info | Aug 31, 2014 13:37 | #5 tgara wrote in post #17127656 If it's as good as you say, the higher-end models should blow you away. Pro-10 and Pro-1, using pigment inks (while Pro-100 is dye ink), are probably geared more towards longevity than punch.
Sep 01, 2014 23:16 | #6 agedbriar wrote in post #17127976 Pro-10 and Pro-1, using pigment inks (while Pro-100 is dye ink), are probably geared more towards longevity than punch. While that's true, it's also true that dye inks generally produce more vivid colors and print well on RC papers (especially glossy) without problems. If you combine the PRO 100 with Canon's recommended papers, modern dye inks produce much better longevity than in the recent past. And if your work is for immediate rather than permanent use, the PRO 100 may well be the best choice. The prints just SING!! It also produces exceptional B&W. If you want to print on fine art papers, a dye printer is NOT a good choice. Canon 7d MkII, Canon 50D, Pentax 67, Canon 30D, Baker Custom 4x5, Canon EF 24-104mm f4, Canon EF 100mm f2.8 Macro, Canon EF-S 10-22mm f/3.5-4.5, 70-300mm f/4-5.6 Di VC
agedbriar Goldmember 2,657 posts Likes: 398 Joined Jan 2007 Location: Slovenia More info | Sep 02, 2014 03:54 | #7 Now I have an old A4 HP Photosmart (dye too) and a few boxes left of the great (discontinued) swellable polymer HP Premium Plus Photo Paper.
vertigo235 Goldmember More info | Sep 02, 2014 21:45 | #8 I love my PRO-100, I don't sell anything I print on it so I don't need it to last 100 years. I can always re-print later (like in 30 years) if I really want to.
Sep 03, 2014 12:54 | #9 agedbriar wrote in post #17130949 Which are the recommended glossy and semi-glossy papers? I would like to check their local availability in advance. Any of the Canon glossy papers, Canon Pro Luster (exceptionally nice) but not the semi gloss - it looks a little veiled. Red River Ultra Pro Satin. Try some of the other Red River papers they are nice, reasonably priced and very supportive. Red River is direct order from their website only. Canson Infinity - any of their RC papers. Canon 7d MkII, Canon 50D, Pentax 67, Canon 30D, Baker Custom 4x5, Canon EF 24-104mm f4, Canon EF 100mm f2.8 Macro, Canon EF-S 10-22mm f/3.5-4.5, 70-300mm f/4-5.6 Di VC
agedbriar Goldmember 2,657 posts Likes: 398 Joined Jan 2007 Location: Slovenia More info | Sep 03, 2014 13:46 | #10 Noted - thank you, rgs!
vengence Goldmember 2,103 posts Likes: 108 Joined Mar 2013 More info | Sep 04, 2014 14:36 | #11 The Pro 100 is unbelievably good for the price. However, be careful buying one for home use, as you can go broke buying frames...
Not to mention ink!! Canon 90D | Tamron SP 35 f/1.4L DI | Tamron SP 15-30 f/2.8 DI VC G2 | Tamron SP 24-70 f/2.8 DI VC G2 | Tamron SP 70-200 f/2.8 Di VC G2 | Tamron SP 2X Pro TC | Tamron TAP-in Console
vengence Goldmember 2,103 posts Likes: 108 Joined Mar 2013 More info | Sep 04, 2014 16:34 | #13 SixDeeFan wrote in post #17135695 Not to mention ink!! A lot of people are getting the rebate and selling just the ink & paper for ~100$ Everything I've heard says the ink will last at least as long as the 50 pages of 13x19, so paper and ink costs you 2$ for a 13x19. Good luck mounting that in any frame (much less matted) for anything near that.
thonee27 Senior Member 297 posts Likes: 29 Joined Mar 2011 Location: Edmonton Alberta More info | Sep 07, 2014 11:28 | #14 http://www.bestbuy.ca …7c50265e244e82ee58973en02
Sep 07, 2014 16:24 | #15 Yes, if you want to learn to print and have complete control of you printed output. But be aware that there is a learning curve. Canon 7d MkII, Canon 50D, Pentax 67, Canon 30D, Baker Custom 4x5, Canon EF 24-104mm f4, Canon EF 100mm f2.8 Macro, Canon EF-S 10-22mm f/3.5-4.5, 70-300mm f/4-5.6 Di VC
| Latest registered member is Niagara Wedding Photographer 875 guests, 162 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
