I obviously should had made an email of each while in PS, but didn't.
Anyway I can, in LR or PS, batch process groups into email sizes, but leave the tiff's as is?
I use LR 5.5 and PS CC.
trailguy Senior Member More info | Aug 30, 2014 12:22 | #1 I obviously should had made an email of each while in PS, but didn't.
DunnoWhen Goldmember 1,748 posts Likes: 16 Joined Mar 2006 Location: South Wales More info | Aug 30, 2014 12:27 | #2 Easiest is to just select the images in LR and export jpgs with the required settings. My wisdom is learned from the experience of others.
DanMarchant Do people actually believe in the Title Fairy? 5,634 posts Gallery: 19 photos Likes: 2056 Joined Oct 2011 Location: Where I'm from is unimportant, it's where I'm going that counts. More info | Aug 30, 2014 22:41 | #3 Yep, just select all the images in LR, then right click and select Export. The dialogue will pop up and you can set where you want them exported to and all the other settings (size, compression, format etc) and it will pump them all out. Dan Marchant
| Latest registered member is Niagara Wedding Photographer 1228 guests, 149 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
