Thread started 01 Sep 2014 (Monday) 17:03
Help with focus stacking
Mr_ipsum
Gallery: 16 photos
Joined Aug 2012
Sep 01, 2014 17:03 |  #1
Hi.
I'm just starting with focus stacking and I keep running into the same problem. Using my 7D and my EF-S 60mm macro I take my shots. I'm using a tripod with remote shutter and manual focus. I've tried shooting at different apertures, f/2.3, f/5, f/8. But each time when I go to stack the photos in PS CC, the software always selects the bottom layer about 95% of it, and masks out all the other layers. The other layers make up the the very fringe of the photo.
The process I'm using is first take the photos while adjusting the focus manually. The tripod is set so the only difference in the shots is the change in framing due to different focus points. I then go to File>Scripts>Load Files into stack. The I check the auto align layers. Then I shift click the first and last layers to select all the layers. I then go Edit>Auto Blend Layers and select stack and check the box to match tones.
Yet after all this only the bottom layer is pretty much all there and all the other layers are masked out. For some of these shots I've taken 10-15 images, so PS should have enough to work with to create a decent image no?
Any advice would be much appreciated.
Thanks!
RichardCervellonePhoto​graphy.com (external link) | Follow me on Instagram (external link)
chauncey
Sep 02, 2014 09:54 |  #2
You should be doing the selecting of all layers>"auto align">"auto blend" by stacking...in that order only! ;)
Mr_ipsum
Gallery: 16 photos
Joined Aug 2012
Sep 03, 2014 10:49 |  #3
I was doing the auto align layers when I import the images to be stacked. I also tried importing the images and then aligning after importing. So I've tried both ways of aligning the images. But I've always aligned before trying to blend the layers.
chauncey
Sep 03, 2014 10:57 as a reply to  @ Mr_ipsum's post |  #4
Assuming that what you're saying is accurate...I would suggest that you link-up with "Adobe chat room live" and have them do a "screen-share" to solve the problem. ;)
pulsar123
Gallery: 82 photos
Sep 03, 2014 14:37 |  #5
I got good results (stacking up to 100 photos with 16 bit colors) with free software enfuse:
http://blog.patdavid.n​et …-macro-photos-enfuse.html (external link)
It does both aligning and stacking steps.
6D (normal), 6D (full spectrum), Tamron 24-70 f2.8 VC, 135L, 70-200 f4L, 50mm f1.8 STM, Samyang 8mm fisheye, home studio, Fast Stacker
Mr_ipsum
Gallery: 16 photos
Joined Aug 2012
Sep 03, 2014 22:36 |  #6
chauncey wrote in post #17133394 (external link)
Thanks, most of the instructions I read seem simple enough, I was just wondering if it could be the images themselves that are the problem. Does it make a difference with a wider DOf vs narrower? Of course I would have to make sure to get enough shots to cover the area I want in focus.
1,129 views & 0 likes for this thread, 3 members have posted to it.
Latest registered member is finnianmarlowe
1337 guests, 177 members online
