Thread started 03 Sep 2014 (Wednesday) 16:47
DIY video slider rail
davebreal
Sep 03, 2014 16:47 |  #1
Finished the assembly today, there's a little play in the coupler that I need to tighten up somehow. Pipes are obviously PVC (from Home Depot), the camera platform is about 1/8" hard plastic that I drilled a 1/4" 20 tripod screw through. Made the base out of plastic electrical boxes.
That's my 7D with the Tamron SP 90mm VC on top of it, and the motion seems to be relatively fluid. I don't see myself shooting with a much heavier right on it anytime soon, and may end up using my mirrorless stuff on it more than anything.
http://instagram.com/p​/sf5SIGqs2A/?modal=tru​e (external link)
Dave
flickr  (external link)Twitter  (external link)Wordpress Blog (external link) YouTube (external link)
My Gear--> Facebook (external link)
BrickR
Joined Mar 2011
Sep 05, 2014 18:21 |  #2
The ones I've seen usually run the pvc into the electrical box.
Did you use felt on the inside of the pass thru for the base?
My junk
The grass isn't greener on the other side, it's green where you water it.
davebreal
Sep 06, 2014 07:00 |  #3
BrickR wrote in post #17138022 (external link)
I didn't follow any plans, mostly winged it.
Yeah, there is a small felt pad on the upper section of each contact part of the the coupler. I drilled holes in the bases of the electrical boxes to stake it to the ground, or wingnut it to lightstands for stability too.
Dave
1,001 views & 0 likes for this thread, 2 members have posted to it.
1096 guests, 119 members online
