Thread started 04 Sep 2014 (Thursday) 13:10
Wedding Remote Camera Triggering
picworx
Joined Jun 2005
Sep 04, 2014 13:10 |  #1
I plan to use a remote triggered 5DMKIII off to the side of the alter. I have tested the trigger and it works great.
The 2 lenses I have for this are the 17-40 f4 and the 24-70 f2.8 so I am debating with lens to use?
The other issue is focal point, I normally shoot the center point but not sure which focus setting might be best as a remote camera and whether a keep alive setting on the trigger would be best here?
The Print is What Really Matters
John ­ from ­ PA
Joined May 2003
Sep 04, 2014 14:15 |  #2
Are you likely to rack that 17-40 to mid range to avoid distortion? If so go to the 24-70 2.8 as best choice.
picworx
Joined Jun 2005
Sep 04, 2014 14:27 as a reply to  @ John from PA's post |  #3
I could do that, but as you say the 24-70 2.8 might be a better choice, which leaves the other questions I have....
GeoKras1989
Joined Jun 2014
Sep 04, 2014 20:18 |  #4
I'd set manual focus to the center of the area the group will be occupying, and the aperture to f/8-11 to cover enough DOF. You can blur the BG later, if desired. You can't sharpen up an OOF subject.
WARNING: I often dispense advice in fields I know little about!
680 views & 0 likes for this thread, 3 members have posted to it.
1510 guests, 132 members online
