I wonder if I will get any help with this nasty but apparently infrequent problem: About a year ago I purchased a new 135L. The hoods of my currently nine EF lenses are each a bit different but none had that particular "dry" feel when mounting that I experienced with the 135. While turning fairly easily, the hood would make squealing or slightly grinding noises, and the fit when locked felt just a bit lose compared to other hoods.
I was always concerned about wear on the hood mount and apparently for good reason: Despite very infrequent use of the lens a recent inspection revealed an alarming degradation of its hood mount with dulled, even ground-off areas.
Needless to say, the lens was never exposed to substantial amounts of abrasive dust, and it has been cleaned regularly and thouroughly. Nor did I misalign the hood or something. There's also no obvious defects on the hood.
So what are my options in order to avoid total failure of the bayonet (at least) or even to return the lens to its original state (at best)?
• I might use a bit of silicone grease as a first aid measure to ease the grinding.
• I could replace the hood to see if the problem persists.
• I could send the lens to Canon for a warranty repair. Being in the second year of EU warranty I'd have to prove that Canon was at fault though. Hardly practical.
• I could request a cost estimate for a repair. Judging from reports about the notoriously delicate front ring of the 50L I'd guess a bill of several hundred Euro. (Edit: The 50L's hood mount is known to come off sometimes, not for wear.)
I wonder if any of you experienced any similar problems and how you dealt with it.
