Thread started 09 Sep 2014 (Tuesday) 18:09
Potential defect: LP-E6 Battery Rattling Noise
outmywindow
Joined Jan 2013
Sep 09, 2014 18:09 |  #1
Hey everyone,
So while out shooting this weekend I noticed that one of my Canon OEM LP-E6 batteries has developed a rattling sound as if something has become dislodged inside the battery. Now this is not the only LP-E6 battery that I own, as I have another OEM and a couple of Wasabi LP-E6's for my camera. I tried to figure out what might be going on but couldn't really come to a conclusion as to what it might be. It does charge fine in the OEM charger (it was at 25% charge after being used in the camera before I noticed the problem) all the way to green (100%) and my volt meter reports a voltage consistent with zero load and the mAh rating of the battery.
Any ideas? I'm assuming that the battery is defective, but does anyone think the battery is still safe to use?
Just a soul with a camera
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Sep 09, 2014 21:52 |  #2
There is a small circuit board inside the battery that hold info like a serial #, etc. It sounds if something came apart on that board, or a soldered jumper line has come free between the cells.
outmywindow
Joined Jan 2013
Sep 09, 2014 22:35 |  #3
Hmm, that's interesting that you mention that because it does sound like it could be something close to that which is making the sound. Is there any non-destructive way to open the battery? Ive thought about trying to fix it as it is basically a new battery (only 60 days old since I bought it). I should also mention that I was shooting at altitude before this problem, would that have caused this type of thing to occur?
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Sep 10, 2014 02:28 |  #4
You might want to first check with canon warranty just to see what they say. I am not familiar with their battery portion of the warranty but 2 months in is not an acceptable length of time for an engineered battery with circuitry IMO. There isn't a great way to open the battery without some damage, and even if you did open it, what would you fix if you did find the cause of the malfunction, unless you have some EE background?
1,122 views & 0 likes for this thread, 2 members have posted to it.
1446 guests, 149 members online
