Thread started 09 Sep 2014 (Tuesday) 20:04
Ruby-throated Hummingbirds - a Photo Retouching Bonanza!
CamFan01
Sep 09, 2014 20:04 |  #1
As bird photographers, we all run into the same issue of unwanted "material" showing up in our captures. We all try to deal with these issues in varying ways, but all in an attempt to improve our images.
I've contemplated this thread over the last couple of months as I've worked and reworked some of the images of hummingbirds I've collected this summer. I don't have the luxury of hundreds of captures per session as others have reported so I feel as though I've got to fight for every image I can get. It has resulted in a lot of practice retouching images that had "obstructions" that I felt negatively affected the image I wanted. I thought there might be some interest on this board in the before and after images as well as the tools and tricks I've learned.
To start, all my editing and retouching are done using Photoshop CS5 on a Windows platform. I hope some of the tools I use are shared with other Adobe photo editing software packages.
1. The first couple of images are my attempts to capture the hummer just outside the flower in order to show the entire bird and flower. As you can see below, there is an unwanted shadow on the tip of the beak.
IMAGE: http://i407.photobucket.com/albums/pp154/vroompuppy/Avian%20Friends/More%20Avians/CE4E4197a_1024x700_zps91779703.jpg
IMAGE LINK: http://s407.photobucke​t.com …x700_zps9177970​3.jpg.html  (external link)
2. The fix I chose was to use the Clone Stamp Tool to select some lighter pixels from the proximal part of the beak and use those to lighten the shaded tip of the beak. Straightforward and pretty easy.
IMAGE: http://i407.photobucket.com/albums/pp154/vroompuppy/Avian%20Friends/More%20Avians/CE4E4197a1_1024x700_zps172f44de.jpg
IMAGE LINK: http://s407.photobucke​t.com …x700_zps172f44d​e.jpg.html  (external link)
3. I liked the bird "reaching" for the Bee Balm in this image, but didn't like the flower overlapping the right wing.
IMAGE: http://i407.photobucket.com/albums/pp154/vroompuppy/Avian%20Friends/More%20Avians/CE4E4234a2_1024x700_zps7c2c8702.jpg
IMAGE LINK: http://s407.photobucke​t.com …x700_zps7c2c870​2.jpg.html  (external link)
4. I used the Spot Healing Brush tool in Content Aware Mode to help remove the flower overlapping the wing and had to finish with a few strokes of the Clone Stamp Tool to renew some of the underwing details. The remainder of the flower was removed using a combination of the Clone Stamp and Spot Healing Brush tools. A little more involved.
IMAGE: http://i407.photobucket.com/albums/pp154/vroompuppy/Avian%20Friends/More%20Avians/CE4E4234a_1024x700_zps95f97e8d.jpg
IMAGE LINK: http://s407.photobucke​t.com …x700_zps95f97e8​d.jpg.html  (external link)
5. Now we have a part of a flower obstructing the tip of the tail of this little guy.
IMAGE: http://i407.photobucket.com/albums/pp154/vroompuppy/Avian%20Friends/More%20Avians/CE4E4236a2_1024x700_zps1945e36b.jpg
IMAGE LINK: http://s407.photobucke​t.com …x700_zps1945e36​b.jpg.html  (external link)
6. I remember being mad that the Spot Healing Brush wasn't doing what I wanted it to do here, so I had to result to the Clone Stamp Tool to refashion the tail tip. I then removed the rest of the flower with the combo of Spot Healing and Clone Stamp. A little touchy, but not terribly complex.
IMAGE: http://i407.photobucket.com/albums/pp154/vroompuppy/Avian%20Friends/More%20Avians/CE4E4236a_1024x700_zpsdf7b8e7a.jpg
IMAGE LINK: http://s407.photobucke​t.com …x700_zpsdf7b8e7​a.jpg.html  (external link)
7. I fell in love with the pose/posture of this image immediately! I also knew that I had to do a better job of revealing the feet. This one was tough! It took me 4 attempts and 2 weeks to finally figure this one out.
IMAGE: http://i407.photobucket.com/albums/pp154/vroompuppy/Avian%20Friends/More%20Avians/DSC_1341c_1024x700_zps0addc0e8.jpg
IMAGE LINK: http://s407.photobucke​t.com …x700_zps0addc0e​8.jpg.html  (external link)
8. Here again is part of the plant obstructing part of the bird. The process I finally used successfully included a pixel mask of just the feet so I could rebuild them first. I re-colored the feet using the Clone Stamp tool and pixels from the small part of the feet not obstructed by the plant. After that, I proceeded to use the Clone Stamp tool, the Spot Healing Brush, and the Healing Brush tool to remove the remainder of the plant below and rebuild the gradient background (more on that in a minute). One caveat.....don't look at the feet too closely!
IMAGE: http://i407.photobucket.com/albums/pp154/vroompuppy/Avian%20Friends/More%20Avians/DSC_1341b_1024x700_zps37890760.jpg
IMAGE LINK: http://s407.photobucke​t.com …x700_zps3789076​0.jpg.html  (external link)
2 big things I learned in doing these and others: 1) apply any noise reduction necessary to the image before using the retouching tools mentioned above, and 2) the best tool for rebuilding gradient backgrounds is the Healing Brush tool. Secondarily the Spot Healing Brush works pretty well too.
I'd like to think that if I hadn't told you about the retouching I did you'd have never noticed it. That would be the main reason why I torture myself this way.
My other hope in doing this thread is to help those interested in cleaning up there images a little bit see that it's not really rocket science. It's mostly about the desire to present a cleaner image and the patience to put up with the tedium that is sometimes required. I've also given those that want to try 4 good examples of before and after images here to practice on if you so choose; and I'd love it if others could add any additional tools and/or methods they find helpful too. My "Image Editing OK" lamp is lit and thanks for stopping in to check these out!
Steve
1DMk4, 5DMk3, D4s, D800
300 f2.8L IS II, 400 f2.8G ED VR, 500 f4L IS, 600 f4L IS II, 600 f4G ED VR....and a few others.
www.pixallphoto.com (external link)
MarkoPolo
Joined Jul 2004
Sep 09, 2014 21:29 |  #2
That is some great post processing! Well done.
Mark
Olympus OM-D E-M1 pro body, M.Zuiko 12-40mm f/2.8 Pro lens, M.Zuiko 50-200mm f/2.8-3.5 ED SWD lens, M. Zuiko EC-14 1.4 Teleconverter, M. Zuiko 60mm f/2.8 Macro lens, M.Zuiko 9-18mm f/4-5.6 lens, M. Zuiko 75-300mm f/4.8-6.7 II lens, Canon 400mm f/5.6 L lens with Canon to OLympus converter, Nissin Di-466 Flash
ldn323
Gallery: 463 photos
Sep 09, 2014 21:44 |  #3
Steve, great job. Thanks for the info.
Wallace ­ River
Gallery: 167 photos
Sep 10, 2014 06:19 as a reply to  @ ldn323's post |  #4
OK, you posted these for me didn't you? :) If you did, thanks Steve, it shows what can be done wth the right skills, tools, and patience. And you see, now I have an excuse....my version of Photoshop (the old Version 7) doesn't have some of the more recent additions like "Context Aware Mode". Sigh. Maybe I should get a newer version! In any event, nicely done, and good work on your part.
My Flickr (external link).
Pondrader
Gallery: 2548 photos
Best ofs: 5
Joined Aug 2012
Sep 10, 2014 06:37 |  #5
Yes it's true...It was for you ....and For me and anyone else that is just to lazy to fix the images right because we all are guilty of sloughing it off from time to time!! I remember back a year or so I left a stick or two in something I put up and some called me on it and from that day forward I have made a conscious decision to understand and use lightroom to its fullest, Im not sure if Im there yet but maybe its time to get CS6 and learn to master it as well. I find it very useful to ask someone what they think because we can look with a jaded eye at our own work.
butterfly2937
Gallery: 378 photos
Sep 10, 2014 07:06 as a reply to  @ Pondrader's post |  #6
Fantastic work and a gorgeous set of images! Great work cleaning up those beautiful images.
GEAR
2slo
Gallery: 1111 photos
Joined Oct 2011
Sep 10, 2014 07:28 as a reply to  @ butterfly2937's post |  #7
Excellent results Steve and a lesson for all who think photoshop is too difficult. As you've shown and talked through, it's straightforward once people take the time to practice and learn. One of the best parts of it is the non destructive design of the layers. When we create a new layer and work on it, if we don't like it we can delete it and the original image is untouched, if we do like it we combine it with the original to enhance the image.
2n10
Gallery: 81 photos
Joined Sep 2012
Sep 10, 2014 08:41 |  #8
Great work and write up Steve. I definitely fall into the lazy camp. I do remove some but not all of the obstructions. Time to up my game and do some serious work on the shots.
John
Equipment
My Portfolio (external link)
Pondrader
Best ofs: 5
Joined Aug 2012
Sep 10, 2014 09:50 |  #9
Here's the way I look at it, I have come to know most of you and Its worth my time to edit my stuff as best I can because your worth it to me. I don't always get it right but I do look for your responds. Its what we do around here lol
TedEllis
Gallery: 101 photos
Joined Jan 2013
Sep 10, 2014 10:55 |  #10
Excellent PP Steve.
Ted
http://www.tedellispho​tography.com/ (external link)
There will be days when you get the shot(s) you missed days, months or years before.
CamFan01
Sep 10, 2014 21:34 |  #11
MarkoPolo wrote in post #17145267 (external link)
Why thank you Mark! That is a very kind and gracious comment.
ldn323 wrote in post #17145291 (external link)
Your welcome for whatever info I could share that will help Linh, and thanks so much for the comment.
Wallace River wrote in post #17145703 (external link)
LOL, you do know me too well Ian :) Of course these were posted with you in mind and at least one other who requested a "tutorial". I've also edited my thread to correct the "Context Aware" to "Content Aware Mode", but it's the same concept of repairing aberrant pixels in patterned areas. I'm glad you appreciated my efforts, and I always appreciate you and your forum friendship.
Pondrader wrote in post #17145717 (external link)
Haha Jeff, if the shoe fits....and who knows, it might have been me that said something :)
I'd agree with everything you said though about how easy it is sometimes to let things slide. All we can do is try to improve as we go along. Thanks for chiming in.
butterfly2937 wrote in post #17145743 (external link)
Thanks so much Carol for your lovely comment. Every hummer image is precious isn't it.
2slo wrote in post #17145768 (external link)
C'mon Mark, now you've gone and made me feel bad because I'm sure I don't use layers as much as I should :) I promise I'll do better in the future!
As always my friend, your comments are spot on and always appreciated.
2n10 wrote in post #17145878 (external link)
Thank you very much John. I really wasn't trying to make anyone feel bad, but we all win with better images.
BTW - you deserve some credit for sending me back to re-learn how to do pixel masks based on a comment you made about masks vs cloning. Thanks for that too!
Pondrader wrote in post #17146006 (external link)
You're too funny Jeff! To put it another way, you can either try to keep up with the competition or you can be the competition. How's that for heavy!
TedEllis wrote in post #17146126 (external link)
Excellent PP Steve.
Thanks as always Ted. I always appreciate your comments.
Steve
Tiberius
Sep 11, 2014 05:02 |  #12
Excellent work!
My photography website!PHOCAL PHOTOGRAPHY (external link)
Bill ­ in ­ Texas
Joined Mar 2014
Sep 11, 2014 05:17 |  #13
Nice work in both areas.
Bill being Smug (external link)
Bill's flickr (external link)
Sony a7, a1, a9, Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS, Sony FE 24-105mm f/4 G OSS Lens, Tamron 70-180mm, F2.8 Di III VXD, Sony FE 200-600mm f/5.6-6,3 GM OSS, Sony FE 1.4X teleconverter
ardeekay
Gallery: 69 photos
Sep 11, 2014 12:38 |  #14
Ha! Like to think I had something to do w/ this in Ian's thread. Boy, if I could get my wife to respond to my suggestions like this, I'd really have something!:lol::lol: Silly me! Seriously Steve, that is top-notch work there. Have to study more to try to improve in these areas-heaven knows, I need to! Struggle w/ the patience necessary to learn and apply. Obviously, not your problem. Again, very well done.
Rog
bigjohninva
Joined Apr 2012
Sep 11, 2014 15:25 |  #15
Great work!!
Bigjohninva
3,457 views & 0 likes for this thread, 18 members have posted to it.
926 guests, 118 members online
